Lobe help pleeeease!
Old 05-14-2007, 12:11 AM
99socalFRC's Avatar
Default Lobe help pleeeease!
OK So I am in cali and I want to keep it smog legal.
Heads will be some version of a 243.
So the cam/lobe options are:
TR224 on a 114
TR227 on a 114
TSP 224/228 581/588 on a 114
TSP 224/224 581/581 on a 114
My question is which lobes are most agressive? I think that from what I have read the TSP will use the XER lobes and that will be the most aggresive? Or would the TR lobes be better?
I plan on using double springs so valvetrain wear/ breakage will be limited.
I just want to maximize what I can do in cali, what does the split do for me?
How much HP gain might I expect from the additional lift on the TSP?
I suspect I am just splitting hairs here so tell me if this is the case?
Old 05-14-2007, 04:23 AM
PREDATOR-Z's Avatar
Yes on splitting hairs
TR224 and TSP 224 (both 114) will pass but only with fresh cats (need check) and good tune.
Ideally to be on safe side a cam with -6* overlap is a sure bet if properly tuned with health motor.
Old 05-14-2007, 03:51 PM
99socalFRC's Avatar
So the TQ/HP #'s on all these cams will be very close then? I have read the split in duration and lift is good for a few ponies, any truth to that?
Old 05-14-2007, 07:06 PM
Dragula's Avatar
Don't you need more exhaust duration and or lift to get through the stock exhaust manifold and cats (smog legal).
Did you look into the TR Cheater Cam?
http://www.thunderracing.com/catalog...vid=7&pcid=122
Or Cam and Head package:
http://www.thunderracing.com/catalog...vid=7&pcid=289
Old 05-14-2007, 08:00 PM
99socalFRC's Avatar
Well I have kooks long tubes and mid pipes so it isn't stock there.
Anyone else on the power potential of each cam listed?
Old 05-15-2007, 12:47 AM
PREDATOR-Z's Avatar
Do some reading, there is zillion of threads on cam that range (use search)
Old 05-15-2007, 10:55 AM
99socalFRC's Avatar
I have read so much already, I just hadn't reallyfound any thingcomparing the 224 options, only the 224's in general I was hoping to decide if the 224/228 would be worth going for, and if the TR lobes made anymore power than the TSP ones.
Old 05-15-2007, 01:03 PM
5.3LJimmy's Avatar
If your trying to pass smog the 224/224 has less overlap and will be the better choice. You wouldn't see a big difference in power w/ a 224 or 228 on the exhaust lobe anyway, nor between the different cam grinds. You're tossing around about a 5 horsepower difference with the options listed. I also found this poll discussing the 224 cams: https://ls1tech.com/forums/showthrea...t=tsp+224+dyno
Old 05-15-2007, 11:16 PM
99socalFRC's Avatar
Thank you, that is what I was looking for just to know what kind of difference I am looking at, if I am running nitrous does the 224/228 advantage become greater?
