Tr 230/224
Tr 230/224
Is anybody out ther using the Tunnder Racing Reverse Split 230/224 .575/.563 111 LSA cam?? I am about to consider this cam and looking for input. My engine is stock except for LT headers and a LS6 intake.
I had that cam in my car and I was very pleased w/ the results. It has good street manners in a 6 speed(I'm sure an auto would be fine w/ a good tune) and makes good usable power. I swapped it out for the MS4 and up to about 4800RPM the 2 cams were indistinguishable by my butt dyno. I ran a low 12's w/ 115-117 trap speeds consistently with stock heads, LT's & ORY, lid & K&N, 12 bolt w/ 4.10's, and LS1 intake.
Originally Posted by badpewter-z
had mine with stock heads loved that cam very good tq curve and drove great.
I have it now, with stock heads as well. Great midrange torque and drives just like stock. It also has a wicked idle, i turn heads everywhere i go.
Thanks everyone, my minds made up!! Ordering it this week.
One quick question to blk97WS6. The idle, was it nice and lopey? Also did it lurch bad in 1st gear like if crawling through traffic or a parking lot??
LS1TECH Sponsor
i drove mine for a few weeks before i junked my 3rd 10 bolt for the 9".
just have to slip the clutch a tad more . the idle is very choppy and mean sounding . you wont be dissapointed at all
The cam isn't designed to work with stock heads as much as it is a stock LS1/LS6 intake. The GM intakes are restrictive, and the additional intake duration is to "crutch" this problem (as described by Geoff Skinner owner of Thunder).
As long as your heads have close the the same intake/exhaust flow ratio as a stock LS1 head, you'll be fine using one of these reverse splits. A LS1 motor that works well with a single pattern cam will work well with a reverse split.
The F.A.S.T. intake will help to eliminate some of the intake restriction, but will still be lacking compared to a good single plane intake.
Ben T.
Ben T.
here's my dyno and mods, https://ls1tech.com/forums/dynamometer-results-comparisons/476349-tr230-224-a4-dyno.html
I love the way it sounds at idle. Completely badass in IMO(for a streetable cam anyway). And mine doesnt bog down or anything in 1st at all, but i have 4.10s. From what the guys at thunder told me, this cam drives ok with 3.42s, but it does do a ton better with a little more gear.
Like everyone said, you wont be dissapointed with this cam.
Blk97WS6, I see in your sig that you are running 100 hp n20 set up. How does this cam respond to it? Normally on nitrous you want the duration split the other way to handle the extra exhaust created by nitrous useage. Curious as to how the engine reacts in any manner. CJay
Cjay, I know this question isn't directed at me, but it is a question that often comes up. As long as you're spraying less than a ~150ish shot, most all of these small cams will respond well. You don't want your camshaft timing tailored for nitrous usage unless you are spraying large amounts of nitrous. Once you're at or above the 200-shot range and spray often, then perhaps a single pattern or convetional split camshaft would perform better.
Ben T.
Ben T.
hey im runnin that cam now with lt's air lid and stock everything else (gears, intake, mass air, pulleys). I have been 11.80's cam only the car is a 02 z28 six speed. it made 390 rwhp on motor and 480rwhp on a 100 shot zex kit with a really safe tune hope this helps. I have not ran the car on spray still on a 10 bolt.
Originally Posted by Blk97WS6
very nice. I havnt been to the track with mine yet because im afraid of breaking the rear. But im glad to see its capable of 11.80's. What was your 60' and mph? and also what tires were you running? Thanks man!
my sixty foot was a 1.70 and my mph was 118. but the ten bolt grenaded the next pass so i stuck a spare i had layin around under the car for time bein till i can get a rear. I was using 26 inch tall m/t slicks on weld rodlites.
I have the TR230 and just love it! It pulls well from the get go all the way to the top in my six speed. It also sounds bad *** thanks to the 111 LSA. Very good cam for a stock motor with bolt ons. Gets a lot of looks at the stop light.
