Nothing good can come from this....
Old 05-14-2007, 06:49 PM
v8juice's Avatar
Default Nothing good can come from this....
I just changed my oil and discovered about 20 or more small, what appears to be needle bearings, that are just under a quarter inch long and smaller in diameter than a standard pencil lead stuck to the drain plug.Here is the kicker...the car runs like a scolded dog and purrs like a kitten.Anybody have any idea where they came from?
Old 05-14-2007, 06:50 PM
sroach20's Avatar
check your rockers.
Old 05-14-2007, 06:51 PM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
word...
Old 05-14-2007, 07:00 PM
Thimble's Avatar
Yep, start shopping for rocker arms.
Old 05-14-2007, 07:14 PM
v8juice's Avatar
OK...any recommendations for rockers on a stock cam and what ratio?
Old 05-14-2007, 07:15 PM
sroach20's Avatar
send your originals off to be rebuilt. its like $250 and they are converted to roller bearings instead of needle.
Old 05-14-2007, 07:54 PM
LS1rulz's Avatar
Yup. There ya go.
Old 05-14-2007, 07:57 PM
bayer-z28's Avatar
I posted a pic of the cam bearing on CZ28 for ya..
Old 05-14-2007, 08:05 PM
v8juice's Avatar
I do not see a link
Old 05-14-2007, 08:46 PM
ArcticZ28's Avatar
Get a set of replacement rockers or have them sent off to Harlan and rebuilt like someone already suggested if you plan on going with a cam in the future. Don't waste your time on different rocker ratios either.
Old 05-15-2007, 08:13 PM
v8juice's Avatar
I really appreciate the help guys but I got another question.I have the valve covers off and there is nothing obviously wrong that I can see.Do I have have to take the rockers out and inspect them, or if the bearing has come apart there should be something I can see or feel with them installed?
Old 05-15-2007, 08:34 PM
jay_99z's Avatar
You may have to pull all the bolts and pull the rockers to inspect them. Chances are.....they will have too much tension on them to really feel anything.
Old 05-15-2007, 09:07 PM
heavymetals's Avatar
Without the bearings you might be able to "push" the rocker from side to side.
It will "wobble"
It will be real obvious when you find the bad one.
I wouldn't just fix the one though.
Old 05-15-2007, 09:19 PM
jay_99z's Avatar
True. Same batch as the others.
Are these mostly 98's? 110,000 on my 99 and never had a problem.
Old 05-16-2007, 06:02 AM
v8juice's Avatar
This is a one owner 98 with only 34000 miles on it
Old 05-16-2007, 09:05 AM
LS1rulz's Avatar
Aah those funky '98 model F-bodies.
Old 05-16-2007, 09:58 AM
sledneck687's Avatar
get them rebuilt for $250 same thing happened to me, only i never was able to find the rest of my missing bearings
Old 05-16-2007, 03:47 PM
v8juice's Avatar
I do not think its a rocker now.I talked to a mechanic that had one come in and with the same situation and found it was a lifter that went bad..o well.But Im going to pull the rockers off and give them a good look,I will let you guys know.Thanks for the help.
Old 05-16-2007, 03:59 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Lifters Don't have Bearings....
It's been Documented many times that the needle bearings fail.
Old 05-16-2007, 04:45 PM
v8juice's Avatar
So there are no needle bearings in the roller lifters.But wouldn't I have found at least one or two bearings still setting in the head? Please do not trash me I am just trying to figure this out so I do not create excess work for myself.Thanks
