Dart 205's or 225's!
Looking at some Dart heads. Are the 205's better than 225's?
The car will have a ported TB, mild cam and true duels with long tubes. Im just not sure which heads.
Also does Dart make decent heads for the money?
Anybody interested in the stock heads?
with a smaller cam you're better off going with the smaller intake runner. it will boost your low and mid range power, with only a small sacrifice on the top end.
the bigger cams like the mid 23x+ would be better suited for the 225 runners.
as for the quality...as the saying goes "you get what you pay for"
they are decent heads for the money, are there better..yes...for $500-1000 more. all to gain maybe 10-15hp.
I have researched this alot and these are good heads. You can do better, if you want to spend another $1k. But it also depends on your needs. If your going to go with a cam that needs upgraded springs from the psi's that come on the darts you might do better with a set of tsp, patriot or livernois 243's that will run you the same to a little more with a double spring setup. But with the darts you are also getting new castings with room to grow (once porting development is further along) for a good price.
Even the 225 is not a "big" intake runner for the 346. If you don't have money to burn, these are a good option and a good buy in my opinion and people are putting down good numbers with these. I would go with them over the 205's.
Heres the specs on the mild cam thats going in:
220/220/116 CENTERLINE, .581 LIFT
Im thinking the 205's will be fine. Im getting them for only $1619 including shipping and with Titanium retainers and Beehive springs. I think the price is ok and they should work pretty good.
The shop where these are coming from said that porting them doesnt warrant much of a hp gain versus the cost to do the work so I opted to not. Maybe down the road when I want to spend more $$ I will put on a 90/90 intake, swap out the heads and go with a larger cam. Also if the funds permit go with a set of turbos and really bump up the hp #'s.
Im also thinking down the road I might like to sell the car and build or have built a Factory Five GTM car with a set of twin turbos and a LS7, my goal would be to get 700 hp in a car that only weighs 2000lbs.
Darts are a great head for the price. I would put it down to one simple question, Do you plan to go with more cubes later? If the answer is yes then buy the 225s. I went with the 205s, which I still have on my 383 now, and need to buy another set of heads to work more efficiently with the 383.
