Lightweight valves
Old 05-17-2007, 07:00 PM
under pressure's Avatar
Default Lightweight valves
I have a GM replacement engine that came from a Z06. Is there any way to tell if the heads have the lightweight valves? I believe the car was originally an '01 and the engine was replaced in about '03. The valve springs are solid blue colored. I hope there is a way to tell without pulling it apart. Pushrod length maybe? Thanks.
Old 05-17-2007, 09:42 PM
405HP_Z06's Avatar
I think the solid blue LS6 springs signifies an '04 LS6. Making the big assumption it was a long block replacement, you probably have the LS6 lightweight valves.
