Need Help Deciding on a cam
Hey guys can anybody help me deciding on the best cam.... Before i have the cam installed i will have long tube headers, full exhaust, ls6 intake, and a cold air intake, i want to make as close to 400 at the wheels as possible with stock heads, no porting or anything, i would also like rocker arms, and maybe valve springs, can anyone give me some good advice, car is not a daily driver but needs to be streetable. i would appreciate any input, thanks .
there is no maybe with valve springs, anytime you do a cam you have to change the springs, as for cam, I would suggest the G5X2, 228R, or get with some of the sponsors like thunder racing or texas speed.
you need springs, pushrods, timing chain, and an oil pump for a cam install...and there are a few other small things you might want to check w/ a sponsor about depending on applications.
