Strongest Stock Crank
Old 05-21-2007, 06:19 AM
Lextech's Avatar
Default Strongest Stock Crank
I have read many times about a stock LS crank handling 900+ horsepower, if the tune and build is correct. But, I have never seen anything about different casting numbers/factory applications as to which crank is better to use than
others. Is there a BEST CHOICE of 3.622 crank to use?
Old 05-21-2007, 08:46 AM
sroach20's Avatar
as long as you dont get an early model 6.0 crank they are basically the same.
Old 05-21-2007, 09:01 AM
MrDude_1's Avatar
not really... noone really breaks any of them...
Old 05-21-2007, 09:43 AM
PREDATOR-Z's Avatar
You can nitrate the crank for additional strengthening.
Old 05-21-2007, 09:53 AM
Lextech's Avatar
Thanks for the info!
Old 05-21-2007, 10:04 PM
MNR-0's Avatar
Nitriding the stock crank often causes the reluctor wheel to fall off. They are a biatch! to get back on. Cold firing the crank is the next safest thing.
Quick Reply: Strongest Stock Crank
