Best head for my setup?
Old 05-22-2007, 09:31 PM
Detoxx03's Avatar
Default Best head for my setup?
I don't know if this is in the right sections so feel free to move. I'm looking to get a set of heads on my car and was wondering what are the best ones? I heard Trick Flows will net the most power and be the most expensive. My concerns are getting the max power with getting maximum driveability. Mods are in my sigs. Thanks guys.
Old 05-22-2007, 09:36 PM
TXZ28LS1's Avatar
i think youll be good to go with the TFS heads! also, if your on a budget, the TSP heads are also proven also.
Old 05-22-2007, 09:46 PM
Detoxx03's Avatar
just a little budget but why not do it right the first time. thanks man
Old 05-22-2007, 09:50 PM
1bad lad's Avatar
check out livernois heads....they made same amount of power as the trick flows and cost way less.....
Old 05-22-2007, 10:57 PM
Detoxx03's Avatar
Okay thanks
Old 05-23-2007, 05:22 PM
Dave@LivernoisDSS's Avatar
Little long of a read.. but good stuff..
http://www.gmhightechperformance.com...ads/index.html
Old 05-23-2007, 05:48 PM
00T\A's Avatar
Man i have just seen and heard too much good stuff abour the tfs 215's.
I will be giving the a try before this year ends.
Old 05-23-2007, 07:03 PM
Detoxx03's Avatar
I think i'm leaning toward trick flows. How much power would it add to my setup?
Old 05-25-2007, 09:33 AM
But why spend all the money on something that you can get for less money?
Old 05-25-2007, 09:42 AM
Kryckter's Avatar
Good set of heads with some added compression can net you up to 40-50 RWHP or so.
Another head to check out that has done proven numbers over and over is the TSP/PRC Stage 2.5 5.3 head.
http://www.texas-speed.com/shop/item...id=84&catid=40
Old 05-25-2007, 09:47 AM
xBROKEx's Avatar
trickflows are like 2500 each and livernois stage 3 are 1700 for the pair. Thats quite a price diff for only a few hp
Old 05-25-2007, 10:22 AM
bobby1's Avatar
maybe i missed it but the stage 3 has a 240 intake runner will that work with a 346 motor just curious i'm getting heads when i can afford them
Old 05-25-2007, 10:33 AM
Kryckter's Avatar
Thats a big runner for a 346 motor. I missed out if you were forced induction or something. If you are N/A, a 200-220 cc runner is about the range you want to stay in for the best power/torque combination.
Old 05-25-2007, 10:44 AM
bobby1's Avatar
trickflow heads flow 320 cfm on intake and 259 on the exhaust and livernosis flow 305 cfm on the intake and 235 cfm on the exhaust it is a difference but not sure how much 15 more cfm and almost 30 more cfm on the exhaust will make
Old 05-25-2007, 10:46 AM
Detoxx03's Avatar
I really need to think this over. I appreciate the advice
Old 05-25-2007, 10:52 AM
bobby1's Avatar
no problem you are right trickflow seems to be the best rightnow depending your going to upgrade to stroker later they would change things too
Old 05-25-2007, 11:10 AM
sdimess84's Avatar
I am wondering the same thing. Im puting a 5.3L into my s10. The only mods are tune and cam (216/220) I have casting number 706s now. Should have them ported, or should I get a different casting number to have ported?
Old 05-25-2007, 11:24 AM
Stang's Bane's Avatar
Trickflows are not $2500 each. they are ~$2500 for the pair fully assembled.
Old 05-25-2007, 11:51 AM
JF-WS6's Avatar
My cam is pretty close to what your running, I went with Patriot LS6 style heads, I did alot of research and I'm very happy with the patriot heads, I ended up with 439rwhp and 388rwtq and that is on a mustang dyno.
Old 05-25-2007, 02:59 PM
RedDemonLsX's Avatar
Get the Trickflows!!!!!
i just ordered my set
