spring removal off of car
Old 05-23-2007, 08:42 PM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
Default spring removal off of car
ok so im having this problem where my heads are off the car and im trying to remove the springs but the valves keep opening what do i need to do to keep them closed?
Old 05-23-2007, 09:17 PM
Eurospec2's Avatar
Default I suggest
I suggest a welder, should do the trick just fine!
Old 05-23-2007, 10:07 PM
Mike94ZLT1's Avatar
Take it to a machine shop and pay $20 to have your heads disassembled
Old 05-23-2007, 10:17 PM
LS1Tech Sponsor
i think thats what im gonna do
Old 05-23-2007, 10:31 PM
fuseone's Avatar
if you are talking about valve springs they sell a tool to take them off it has this thing that you screw up to the valves and it holds them there while you put the springs down to get the keepers off.
Old 05-23-2007, 10:35 PM
fuseone's Avatar
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1 they sell other ones to.
Old 05-24-2007, 12:16 AM
eallanboggs's Avatar
If the welder doesn't work how about gravity? Try taking the springs off with the head upside down.
Old 05-24-2007, 11:34 AM
Xtnct00WS6's Avatar
All you need to do is put a small socket under the valve (or something of similiar size). That'll prevent the valve from going down. You'll have to put some weight on the head too. I've been using the Moore spring compressor tool and that's what I do and it works like a charm. It's a POS though...I've used it on about 3 spring swaps and it's already warped and literally falling apart.
Old 05-24-2007, 11:43 AM
408 z28's Avatar
i use a socket and a hammer works everytime
Old 05-24-2007, 11:47 AM
PAGregSS's Avatar
It's not big deal if the valve opens. Just sit the head on the bench with the chambers face down. Once you have the spring compressed, just tap the retainer with an extension and a hammer. That'll pop the keys loose.
Old 05-24-2007, 11:53 AM
LS1Tech Sponsor
k thanx eveyone ill try tonight
Old 05-24-2007, 12:18 PM
99blancoSS's Avatar
I used my fingers. Laid the head on its side on my work bench.
