Light rust on 2 cylinder walls/sleeves - What to do? pics
Old 05-27-2007, 10:59 AM
stealth71's Avatar
Default Light rust on 2 cylinder walls/sleeves - What to do? pics
Well I guess the last time I put the motor away all the cylinders didn't get lubed properly. Now there it some light rust on 2 of the cylinder walls.
What should I do? Not worry about it or the other extreme, pull the motor apart and have it honed, possibly bored and new pistons? Any other ides?
I just don't want to loose the motor over it and waste all the money in cam, oil pump.....
The others look fine:
Old 05-27-2007, 06:00 PM
Grimes's Avatar
i would try an oily scotchbrite pad, lightly work the area, and see if you can get it to were you don't feel the rust anymore.
Old 05-27-2007, 06:48 PM
dnm12's Avatar
what about carb cleaner and your fingers?
Old 05-27-2007, 07:05 PM
MorePowerPlease's Avatar
I agree see if you can get it to the point where u don't feel anything.
How long has the engine been sitting. Seems like there is alot of rust in other places. Use a gaint trash bag to cover and cut air off when storing.
Quick Reply: Light rust on 2 cylinder walls/sleeves - What to do? pics
