Crane cams dual valve springs?
anyone hear anything good about them. for the price them seem like a good deal.Crane vlave springs
i'm looking into the #144832-16 i'm changeing them due to the comp 918 haveing problems. also for the fact that im playing russian ruelet with the size of my cam. do you know if the stock retainers and seats will work or should i look into some titanium retainer and aftermarket seats?
Stock retainers and seats will not work with the crane 832's. The crane springs are not a "beehive" design like the stockers or the 918's. I am in the same boat as you. I have 918's ready to go in but hear enough of these breaking that I am a little nervous. These were to go with crane 1.8 RR's on a stock cam, so a very mild set-up but I still don't know if I trust the comp 918's.
Crane sells the proper seats and retainers for the 832's and offer both steel or titanium.
the 832 will do good for 6500 rpms.
http://vincihighperformance.com/superwebdeals.HTML
if you are going higher, i'd recommend the 833.
http://vincihighperformance.com/NEW%...TS%20PAGE.HTML
Understand your concern on the 918's, someone in Australia just lost a motor from a new installation of the 918's and they are getting a real bad reputation on their boards because of it.
I would go with the 833's myself, they are comparable to the Comp 921's and a little less money.
On the 832's, they set up light on the seat so figure out what you need for seat pressure and shim accordingly. Without shims, they will setup at approximately 122 lbs. They are designed to be versatile, but in doing so you need to shim them. Not a big deal, but just make sure you set them up correctly which you should really do with any valve spring.
i've been hearing alot on the whole 918's breaking and i think comp should make good on their defective parts. springs aren't that expensive but its just a waste of money to buy these and have them break or even worse put a hole in you piston. but a friend of mine is selling me his patriot golds so i think when it comes time to change them i'll be going with the comps.
Originally Posted by vettenuts
As an aside, my new Crane Newsletter included an announcement of their new beehive design. I have another thread I started with the information.
