Exhaust banging off of crossmember
Old 05-29-2007, 09:16 PM
30th t/a's Avatar
Default Exhaust banging off of crossmember
what can I use to wrap around the exhaust pipe to help keep the exhaust from banging off the crossmember and possibly causing knock? would heat wrap work?
Old 05-29-2007, 11:38 PM
3.4camaro's Avatar
shove an old brake pad in between em. It will keep pressure on both so they wont move and it won't melt, either.
Old 05-30-2007, 01:58 AM
cals400ex's Avatar
i am having the same issue. i need to think of something good to put in there as well.
Old 05-30-2007, 07:21 AM
GMTECH4's Avatar
i had the same problem. i cut about 1/4 of a inch off my magnaflow I-pipe that connects to the y-pipe and grinded a small chunk off the corner of my crossmember. now if i could get that u-clamp to stop banging the driveshaft tunnel?
Old 05-31-2007, 07:48 AM
oldguy99Z's Avatar
As was suggested by others on here in previous threads i used a piece of heater hose.Get a short piece of 1" heater hose and slit it lenghwise-it will fold over the pipe and wedge between the pipe and floor.
Old 05-31-2007, 09:35 AM
slt200mph's Avatar
Welcome to the club sir ... there are many here amoung us ... there are countless ways to cure it ..
Old 05-31-2007, 06:55 PM
GMTECH4's Avatar
heater hose didn't work for me! made it worse for me
Old 05-31-2007, 07:02 PM
NC98Z's Avatar
Y'all do a search on bump stop and you'll find out there are 2 kinds. 1 for the TB and 1 for the exaust. I can't remember who I bought mine from but they make a hanger just for that pesky rattlin bitch.
Old 06-01-2007, 05:36 AM
PREDATOR-Z's Avatar
Also poly motor mounts help.
Quick Reply: Exhaust banging off of crossmember
