98 valve covers wont fit 5.3 heads right?
Old 04-30-2003, 01:02 PM
98TAauto's Avatar
Default 98 valve covers wont fit 5.3 heads right?
just found this out... but they wont fit right? The bolt pattern is different?
Old 04-30-2003, 01:04 PM
Constrictor 98TA's Avatar
Default Re: 98 valve covers wont fit 5.3 heads right?
That is correct. The 97-98 heads are the only LS1 style heads that have the perimeter style bolts, and the valve covers only work on those heads. All the LS1 style truck heads have the center bolts. You can still use 5.3L heads on your 98 engine though, you'll just need to get two new valve covers, new coil brackets, and you may need to do something with your PCV system since its in a different location on the 97-98s than any other year.
Old 04-30-2003, 01:05 PM
TransAm98's Avatar
Beat me to it :p I didn't know the pcv system was different.
Old 04-30-2003, 02:16 PM
Display Name's Avatar
What do you have to change on the pcv system?
Old 04-30-2003, 03:02 PM
98TAauto's Avatar
im not worried about the PCV system since I already have that catch can mod and I can arrange that any which way
hmmm now's the time to get a polished set of valve covers LOL
so i need the covers and brackets
anyone have good prices on the set?
Old 04-30-2003, 04:42 PM
Phil99TA's Avatar
The PCV fitting on the back of the drivers side valve cover is different on center bolt/perimeter bolt covers. You'll need the right one.
