Took my lifters off, how can i tell if they were the cause of ticking, can i check?
besides for installing my new lifters and turning the car on to see if the clicking stopped, how can i tell if the lifters were bad? is there anyway to check the lifters? i mean the only thing i found was one of the lifter's rollers had alittle more side to side movement then the rest
The only way a lifter would make a noticable "clicking" sound would be if it is collapsed. Try taking a pushrod and compressing it. If the piston moves down alittle bit, and then back up it is probably fine. Has the engine always done it or did it suddently start? It is possible that one of the rockers loosened or was never tightened down all the way, causing the sound also.
I had a problem with my 95 Z that i would occosionaly get a odd noise that sounded like it was coming from under the passenger valve cover. I swapper out the whole complete valve train, i mean lifters, pushrods, rockers, springs, all hardware... Noise was still there. My dad walks in there and notices there was 2 header bolts missing on the front of the passenger side header. I threw 2 bolts in, problem solved. I can not believe how much they sounded the same! Easy thing to check that may save you lots of time...
