408 running like CRAP HELP!!
Ok, so I was driving my car the other day on a cruise. The car was running prfect, then like a flick of a switch, it started bogging and running like total ****.. couldnt keep it running with out giving it 50% throttle until i could get to the shoulder of the road.
best way to describe it is to take a SBC 350 and scramble up the plug wires.. it will run but only barely.. like it only has 20 hp or something.
so i get a tow home, and after finally getting it started, and babying the throttle until it would finally idle (sounding sick at best) i went to the front of the motor and heard a sucking noise comming from the air lid like i have never heard before.. sounded like a porta poty truck cleaning the **** house.. LOUD!
the Fuel presure guage was bouncing...almost viberating between 40 and 60 lbs.. not holding steady.. when i shut it off, it maintaind over 50 psi while just sitting.
I reverted back to a stock misfire table to scan misfires at RPMs above idle, and it did have a few misfires on the number one, but all cylinders where firing..
Any Ideas?
i have checked ALL the grounds
the racetronix wiring
Any Ideas?
Originally Posted by soulless
Have you tried to locate the source of the sucking noise, could just be a vacuum leak.
the throttle boddy.. when the idle drops below 1k rpm it tries to keep itself running and sucks in MASSIVE air
here is the codes i scanned just now.. looks like its definatly electrical
[PCM] P0200 - Injector Control Circuit (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0300 - Engine Misfire Detected (History) (Immature)
[PCM] P0443 - EVAP Purge Solenoid Valve 1 Control CKT (SES) (Pending) (Old) (History) (Current) (Immature)
[Brake] U1000 - Class 2 Communication Malfunction (History)
[Restraints] B1000 - ECU Malfunction (History) (Immature)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1301 - Class 2 Short to Battery (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Restraints] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
Originally Posted by Joel_SS
Fix the vaccum leak.. You car will run like **** with a leak like that, and it if bad enough it will not run at all..
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
Sucks Chris esp after all the money that was spent. If you need my help give me a call and I will roll up there to the house k. Like I said before on PHFBA either something was grounded or shorted out somewhere. I hope its something cheap and simple. I am trying to remember about the CPS I will look it up when I get home. I have a few books to ponder through.
Best luck though bro
It sounds electrical. The very first thing I would check is the battery/alternator cables. If one came loose.. check them by the starter too. All that stuff was removed and put back on I'm sure during your 408 swap. If that was ok, I'd check the PCM plug as well as other plugs and make sure everything is tight. Swapping in a known good PCM would be something to consider.. not sure how much trouble it would have with the 408 but I'd think it would idle at least.
