ARP head BOLTS torque like the studs?
I'm about to assemble this thing, I have a set of stock GM head bolts here. After doing some research I think it would be worthwile to upgrade the head bolts. I'm not too keen on spending $250 for head studs, the $140 for the bolts seems reasonable to me. I spoke with ARP and apparently they torque just like the studs do? Is there any reason I should spend another $100 and get the studs, if the bolts will get rid of the torque to yield process?
Originally Posted by 2 SSlow
the BOLTS do get rid of the torque to yeild bullshit. Thats one of the reasons i bought them lol
Lol, I capitalized BOLTS so people would know I didn't mean STUDS
Originally Posted by bsf
One thing to keep in mind when using studs, I have read some people have problems getting the heads on if the swap is being done with the engine in the car. I just bought the ARP bolts.
I spent the extra for the studs, and don't regret it at all.
I just did a head swap this last week, with the motor in the car and I used ARP studs with no issues at all! Driver side peice of cake, Pass side I had my wife use a bar to hold the wire harness out of the way and everything slipped right inot place. If I ever take these heads off I dont have to clean the hole again and that sucked!
I use the studs, but one thing to keep in mind is if you do buy the studs, bolts or whatever, DEFINATELY buy a bottle of the arp lube to go with it. the packet is enough to get them installed, but if you ever ever have to take it apart again you'll need it.
You can use 30 weight oil, but the ARP moly lube is definetly preferred.
