yella terra shims where to buy?
Old 06-07-2007, 07:11 PM
92slowmaro's Avatar
Default yella terra shims where to buy?
ok so i picked up a set of yella terra 1.7 rockers for really cheap. so i went to check the valve lash and im definately going to need the shims.
so where can i pick up a set of shims for them?
thanks,
ryan
Old 06-08-2007, 10:42 AM
Craig@ETPerformance's Avatar
You can get shim stock from places like J&L, MSC or Production Tool if you are in a pinch. If need be, you can use hardened washers depending on the thickness you need.
Old 06-08-2007, 12:04 PM
92slowmaro's Avatar
alright thanks for the info.
