224 degree cam and intake center line
Old 06-07-2007, 08:03 PM
Formulated's Avatar
Default 224 degree cam and intake center line
Those of you guys with 224 degree cams: what ICL are you running, and where does your engine make peak power? (or just how high do you run it?). I guess what I'm really looking for is a relationship between IVC and the engine speed at peak power.
I just picked up an XER273 cam, it was a good deal. It is a 224 / 230 degree cam on a 114 LSA. According to the cam card, ICL is 112 when installed straight up. I was thinking of putting it in at 108 to get peak power at lower rpm. I have an A4, and I don't really care to rev it to the moon. If I could get peak power before 6000rpm I would be really happy. (though I think the LS1 heads flow well enough that a relatively short intake duration will still peak pretty high).
Old 06-07-2007, 08:41 PM
1989GTA's Avatar
By advancing the cam some more you also will increase your dynamic compression ratio along with moving the valve events around. Normally Comp Cams comes with 4 degrees advance already built into them. I think you would likely to more harm than good with another 4 degrees advance.
Old 06-07-2007, 11:08 PM
Formulated's Avatar
If I understand the usual advance math that people talk about, then I think my cam has 2 degrees advance (112 ICL and 114 LSA). I don't really care much about the advance on the cam, it's all relative, and it's just a shaft with lobes on it. I'm more concerned about where IVC should be to keep the peak power engine speed in a reasonable area. With regards to DCR, I'm putting in a cam that has IVC much later than the OEM GM cam, so my DCR will be lower than stock (decreased from where the engine is now). I don't have any problems with the stock cam that I can relate to DCR, so I should be in good shape.
Old 06-08-2007, 09:08 PM
Formulated's Avatar
TTT... come on guys... you must know what your ICL is!!!
Old 06-08-2007, 10:04 PM
Ryan02SS's Avatar
TR224 112LSA 108ICL With my Stage II heads it peaks just a tad over 6000 rpms and holds flat to 6400rpms. Peak torque at 4900rpms.
Old 06-08-2007, 11:03 PM
ExceSSive's Avatar
TR224 113/ICL109 peaks 5850
Old 06-09-2007, 03:19 AM
PREDATOR-Z's Avatar
You should make your IVC no lower than 42, that is ~6200 rpm peak
I would keep the cam as is with no advance, this way it is more intake biased from TDC and will have a nice carry after peak.
Old 06-09-2007, 10:22 AM
JPH
JPH's Avatar
107 ICL on certain set ups here.
Old 06-09-2007, 11:11 AM
Formulated's Avatar
Thanks for the information, guys. The more I get the better.
I figures for ICL and IVC are:
112 ICL / 44 IVC (ABDC)
110 ICL / 42 IVC
108 ICL / 40 IVC
The 42 degree suggestion by Predator might be pretty good. The other point I didn't mention is EVO. I don't want it to be any earlier than it has to be, but with a 230 degree exhaust lobe, that may be a bit difficult. with the 110 ICL, EVO will be 53 BBDC. (BTW, these are all 0.050 lift values I'm talking about)
Quick Reply: 224 degree cam and intake center line
