Update on P/V clearance with my H/C combo
Well, today i got around to check the P/V clearance with my large cam, with .30 milled 5.7 SII heads, here are the results: I clayed the top of the piston, put the head on, etc... Rotated the motor over one full revolution, it spun pretty smooth, unbolted everything, pulled the head off, and sure enough, the intake valve went right through the clay and just hardly hit the top of the piston . So now, once again I have to send off my BRAND NEW HEADS, and exchange them for 5.3 truck heads, milled only 3 thousands for straight-ness. Also, one question. It looks as though if i used the head gasket, the valves wouldn't touch, would .35-.40 thousands be to close to be safe? Would getting 5.3 heads solve this problem? do 5.3 truck heads flow just as good?
Re: Update on P/V clearance with my H/C combo
A few things...how did you have the setup during the check? I typically use an old headgasket (to simulate compressed thickness) and bolt the head down with 2 or so bolts. I use a real light check-spring to hold the valve and tighen up to zero lash. Then I spin the motor over.
.035 is too tight (trust me ) Most say go for .080 PV clearance though I'm running mine at .070
Ported 5.3s will flow as good as 5.7s. unmilled heads will buy you another .030 in PV clearance. Mix that with the compressed thickness of the gasket and you should be good to go
Where is the best place to get the Isky tool? Best price?
Joe
Joe
I have a new and unused one for someone who wants it.
