[VIDEO] My 382 Stroker ..some ear candy for 'ya
Well my 2001 C5 A4 is back from Mike Norris with a complete rebuild of my engine. If you aren't familiar with my story, I lost the engine January 18 after toasting the #7 cylinder at the track..I limped home that evening blowing white/grey smoke from the exhausts, I had the car flatbed towed to Mike Norris in Orlando the next day and after 3 months the Lunati 382 LS1 is finished. I hope the link works for 'ya.
Here's a video of the result.
http://temp.corvetteforum.net/c5/vst...keridlewmv.wmv
Restricted User
Re: [VIDEO] My 382 Stroker ..some ear candy for 'ya
Ditto for the cam info please and also any dyno numbers yet. I remember when your **** went, that sucked, but sounds better now than stock!
It's a Lunati 232/236-575/578-112LSA You might think it unusual to use a 112 LSA but Mike wanted it that way. The Stage 2 heads were prepared by Wade Stevens from Agostino Racing Engines. We installed a fresh set of 30# SVO injectors as well..and a few other small Hi-Perf parts. The LS1 Edit was done by Tim of C&S Performance Engineering of Orlando who works with Mike. I will be installing a Random 2 3/4 mid/x-pipe this week and then back to the Dyno jet and LS1 Edit for the finished tuning..I'll post the results..should be wicked when it's done Then....it's off to the track again for some real #'s.....I'm looking for bottom 11's ..maybe even touch the 10's with some good air and tractiion..Wish me luck!
what springs are you using ,agostinos? she sounds sweet !!! that is what my car should sound like ! but it doesnt not even close . and you do know its now a 383 right ?
what springs are you using ,agostinos? she sounds sweet !!! that is what my car should sound like ! but it doesnt not even close . and you do know its now a 383 right ? ....bdawg/98mechamta#9
The video didn't work for me . All of my other wmv files work . Said the file type was not supported . Is there some trick I can use to make it work this time?
