Pinning balancer - how many pins to use?
Old 06-09-2007, 09:12 AM
Mike94ZLT1's Avatar
Default Pinning balancer - how many pins to use?
I've got the crank pinning tool and a handful of pins... Is 1 pin sufficient or could I throw another one on there just opposite for good measure?
Old 06-09-2007, 09:45 AM
405HP_Z06's Avatar
One is usually sufficient, two are desireable for forced induction applications. If you choose to use two, make sure your balancer has two key ways.
Old 06-09-2007, 10:04 AM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
One should be good, but since you have more why not go ahead and use 2. Your real worry is the crappy stock balancer coming apart. While you're in there replace it with an ati. I've seen stock balancers come apart and destroy supercharger brackets, steering racks, etc. Pinning the balancer only protects you if the balancer actually stays in one piece.
Old 06-09-2007, 11:56 AM
Dan_the_C5_Man's Avatar
One is more than enough.
Old 06-09-2007, 02:57 PM
Mike94ZLT1's Avatar
Eagle crank, powerbond pulley. I'm just gonna use one, the motor is naturally aspirated.
Old 06-09-2007, 06:56 PM
BIG BAD BLACKSS's Avatar
Use 2, why wouldnt you? All your loosing is maybe 20 minutes of your time and you will feel much safer always. Or be lazy, use one, and always wonder about it.
Old 06-09-2007, 08:34 PM
2000LS1TA's Avatar
Old 06-09-2007, 08:41 PM
405HP_Z06's Avatar
I wouldn't call it lazy, 99.9% of balancers don't have two key ways.
