Running PRC dual golds with MS3, now going to smaller cam and have some ?'s...
Old 06-10-2007, 10:22 AM
erikthegoalie's Avatar
Question Running PRC dual golds with MS3, now going to smaller cam and have some ?'s...
As the title reads, I am currently running a set of PRC 5.3 heads with an MS3...the valve springs are the dual PRC golds, good to .650 lift I believe....
I decided to swap cams to something smaller, the equivalent to a g5x1 to be exact.
I have some questions...
Will the springs need to be swapped as well? If not, will the seat pressure created by the Golds be a bit much for a cam with .588 lift? Remember, the MS3 is .603/.609
***as a side note, is it a good rule of thumb to always change valve springs when changing cams?
THANKS!
Old 06-10-2007, 10:42 AM
BlueGoat06's Avatar
i have the TSP 228R with PRC duals pretty much the same as Patriolt Golds, been running that setup for almost a year/10k miles. so the're fine for a .588 lift, XER Lobe cam.
how many miles do you currently have on the patriots ? from there you can decide whether or not to replace them. if you have less than 10k miles, i think it would be ok to keep them.
Old 06-10-2007, 11:15 AM
mochiles's Avatar
When I put my heads on I had the option of keeping my old Patriots which had maybe 5k miles on them. But I decided to put on new ones just for peace of mind. Plus those lobes a pretty aggressive. You are going to be under there anyway what's another couple hundred bucks?
Old 06-10-2007, 12:36 PM
2000Hawk's Avatar
Why you changing out the MS3 Erik? Don't like the powerband or shooting for a different set-up?
-Joel
Old 06-10-2007, 02:22 PM
sidewayz28's Avatar
try a torquer 2....and i use my patriot golds with less then .600 lift theyll be cool
sidewayz28's Avatar
hey eric are you on stock 3.42s? assuming your a M6?
Old 06-10-2007, 04:48 PM
Hey buddy
I was running 4.10's....but i blew that 10 bolt into outer space on an 1/8th mile a few weeks ago
I am back to 3.42's now, yes
-Joel
Hey Joel,
Well I am planning on spraying a nice 50-75 shot at the track, and the MS3 may be a bit much for the stock bottom end to handle with that shot...
plus, yes, the powerband is a BIT high....I picked up a 228/232 112+4...aka STREET SWEEPER lol..
I am still debating whether to put it in or not though...I do love the MS3 90% of the time...too bad my idle is ****
Erik
Old 06-10-2007, 04:49 PM
ps- my new combo has only 1000-1500 miles on it....not much at all as I NEVER drive her....hell the PRC golds are probably fresh as hell lol
Erik
Old 06-10-2007, 05:06 PM
That's what she said...
TheBlurLS1's Avatar
I ran PRC duals with the stock cam for about 10k miles. Don't ask.
Old 06-10-2007, 05:43 PM
ls2 bait's Avatar
the duals will be fine. what lobes is the new cam on? the xe or xer's? if its on the xers id def leave them be.
Old 06-10-2007, 05:57 PM
BriancWS6's Avatar
Your good with those springs eric. I ran duals in my old car with a 225/225 cam, and run duals with the 228/230 cam in this car.
Old 06-10-2007, 09:07 PM
cool thanks fellas...
Tommy, dont knopw what kind of lobes they are...I will ask the guy...it was a custom grind from comp..
maybe he knows..
Maybe Ill have it doctored....how much does that cost anyway?
Erik
Old 06-11-2007, 10:35 AM
GuitsBoy's Avatar
The duals will be fine. Youre not in danger of collapsing a lifter. Unless youre intentionally looking for a very light valvetrain, no such thing as overspringing a cam. Atleast not with gold duals.
Old 06-11-2007, 10:49 AM
Kryckter's Avatar
Originally Posted by erikthegoalie
Hey buddy
Erik
Idle quality is going to be in the tune, you really cant blame that on the cam, well not a MS3 that is.
And you can easily spray a 50-75 shot on your current setup. Once again, make a safe tune, dont spray in the lower RPM's to keep your torque in check, and it will be fine.
Old 06-11-2007, 04:02 PM
regorih383's Avatar
why? what happend?
Old 06-11-2007, 07:48 PM
venom ws7's Avatar
Still not happy with TQ numbers so you spraying the hell out of it.
Good luck man.
Old 06-11-2007, 08:07 PM
MARKSZ71's Avatar
large cams suck
Old 06-11-2007, 08:28 PM
no I was going to a smaller cam which will make more torque, THEN spray!
Old 06-11-2007, 08:45 PM
venom ws7's Avatar
I dont think you can get more TQ Unless your doing something do the heads.
Did you dynoed the car with 3.42 or 4.10?
Old 06-11-2007, 09:42 PM
sidewayz28's Avatar
lol id'a been more then happy with those numbers.. then with a 100 shot you would really got some torque..
