"Budget" stroker parts..How reliable?
I'm having a 383 built for me by a tech sponsor & I am assured that Scat rods with ARP 2000 rod bolts/Eagle crank is OK.
Well..I'm hoping it's better than stock stuff..But just how good is it?
How hard can you turn & 383 with these parts?
I really wanted Comp star stuff but this was the next engine in line available.
This has to be the last motor I put im this car.
Has anyone here had an unexpected..Or should I say ..An unreasonable engine failure directly related to running Eagle/Scat stuff?
Something not related to abuse/improper assembly..If you were making 1200 RWHP spinning 7500+ RPMs & broke a rod/ crank thats not what I'm refferring to.But please post anyway.Pics of the destruction would be cool.
Originally Posted by GuitsBoy
Agreed. Also fit and finish. closer to being balanced (crank). Country of origin plays a big role too!
So the consensus so far is that these "entry level" budget parts are more than adequate for a "street car"..The difference is that,on average,these parts require more labor to balance or otherwise "make right" before assembly.They are heavier than more expensive forgings & as a result have less RPM capability.
How much heavier?
What is their RPM capability?
Can I safely spin them to the limit of a Comp 921 valve spring(approx 7K) ?
Then there's little issue of contributing to the trade deficit with China.
My experience with CHICOM made speed parts thus far has been poor (PRP Intakes=junk).I hope something as critical as bottom end parts is a better engineered part.
How much heavier?
I don't think that you should be worried what so ever. We have built HUNDREDS of short-blocks without a single problem! We have built short-blocks to make over 1100 RWHP with turbos, 700 with a blower, 800 on the bottle with these "entry level budget parts!" I think you can spin it to whatever you would like without any concern. We can build you one with a Lunati billet crank and rods but at the end of the day it is going to do the same thing. Again, I don't think you are anything to worry about.
