Pushrod Length
Old 06-13-2007, 05:23 AM
KONG's Avatar
Default Pushrod Length
I have a 228/232 cam .6xx, .6xx on a 111 lsa, would the stock length pushrods be sufficient??? Or would I need shorter or longer pushrods?? Not sure what the base circle is. Any help would be appreciated.
Old 06-13-2007, 05:37 AM
RedWS6 00's Avatar
I brought a cam a simular size to yours, I also brought heads and push-rods from the same sponser.
Their message was:-
"The 7.425" pushrods we usually like to recommend to keep you lifter preload the same as the base lobe on the cam is often smaller on aftermarket cams."
Old 06-13-2007, 09:02 AM
GuitsBoy's Avatar
Most aftermarket cams have a 1.450 base circle as opposed to the stock 1.550, meaning youll need a .050 longer pushrod to compensate. Stock PR's are 7.380, so a 7.425 will be .045 longer. Almost perfect.
Old 06-13-2007, 09:45 AM
PortPros1's Avatar
We have had good luck running the Comp Cams 7.400 length pushrods, but I have seen a 7.350 length pushrod go into more than a few LS1 motors.
You can check if the valves are hanging open using compression tester, I would install the 7.400 in one cylinder and check to see if the valves are closed. It may save you some time.
Harold
Old 06-13-2007, 01:51 PM
KONG's Avatar
Harold
There are 7.400 chromemolys in it now. Just trying to figure out what is going on with valvetrain noise. It could be that my lifter preload is off somehow. Thanks for the info.
Old 06-13-2007, 01:54 PM
KONG's Avatar
That is something that I did not know. I figured I would be able to get away with 7.400 as recommended by my engine builder. I guess sometimes they can be wrong too. This is a problem that I do not want to let go, and potentially mess up a brand new motor. Thanks for the advice man.
Old 06-13-2007, 01:58 PM
SSpdDmon's Avatar
Harold
Yeah...the previous owner had my car at a shop that thought 7.35" pushrods were a good idea. I thought it was the typical sewing machine noise when I bought the car. Then, my mechanic told me (after checking with a dial indicator) my preload was only 0.005"......not 0.050".....0.005"!!!!! I run 7.4's now...
Old 06-13-2007, 02:00 PM
GuitsBoy's Avatar
7.400 is not necessarily incorrect, it simply means youre running .025 less lifter preload. The hydraulic lifter fills with oil and takes up and additional play. if the cam's base circle is indeed 1.450, then 7.425 will get you closer to stock. But I am sure the car will run just fine with 7.350 or 7.400. I remember my stock lifter preload being on the order of .080, so theres some wiggle room.
Old 06-13-2007, 02:13 PM
KONG's Avatar
Hey thanks again man for the advice. I didn't realize there was so much "wiggle" room as far as preload goes. I am still learning at all this stuff, I think I need to do better research on parts next time I do an engine build up.
Old 06-13-2007, 02:18 PM
JDM74's Avatar
What heads and head gaskets are you running? Stock?
Old 06-14-2007, 11:24 AM
KONG's Avatar
Running stock ls6 heads and .040 cometic headgaskets.
Old 06-14-2007, 12:39 PM
mikespeed95's Avatar
just get a comp cams pushrod checker and follow the instructions if your less than 100% sure.
