Engine Ticking finally resolved.
I was getting a weird tick/chirp from the motor. I posted a thread before, but I can't find it...
Anyways, I finally pulled the motor apart. I found this guy on the driver's side, front lifter bore: Cylinder 1?
The new lifters slide smoothly in all bores.. so I assume everything will be fine with the new lifters + cam + valvetrain.
Surprisingly, the cam looks AWESOME for it chewing a lifter. Is it repairable? If it is, is it worth selling, or should I just toss it? I already bought a new cam for myself...
Originally Posted by Beaflag VonRathburg
I was about to say is you're cam messed up, then up comes the last picture. I don't know if it's trashed or not, but if anything that lobe will be smaller if you decide to have it repaired. I'm no expert, but I'd say just get it a new cam.
Are you sure you don't have binding valve springs?
Are the springs rated for the lift?
Did you confirm the P to V clearance when you assembled?
I only ask so you don't kill a second cam/lifter or worse.
can't really tell from the foto from the cam, but i have had race cams (lobes) reground that where damaged quite badly.
Although that engine didn't require different new components like pushrods that would add to the cost of the reground upto the point of it being more expensive then to just replace the cam
