what pulley do i need?? my asp wont fit.
Old 06-17-2007, 08:25 PM
santiago's Avatar
Default what pulley do i need?? my asp wont fit.
i ran my asp fine on my 346. now i get a 408 and the crank has this little thin peice of metal...some kid of a locker or some thin. can someone give me a link or point me out to which pulley i need.
you can clearly see that the pulley will not nount with that lil peice of metal on the crank
Old 06-18-2007, 09:07 AM
santiago's Avatar
well after doin some research i guess i need a powerbond
Old 06-18-2007, 11:09 AM
99blancoSS's Avatar
keyed crank, nice!
Old 06-18-2007, 03:45 PM
SOM 02's Avatar
i looked at my pulley when i got home from work and looks like i gotta get a new one also. just another expense for me to have
Old 06-18-2007, 04:50 PM
magius231's Avatar
you can probably have a good machine shop machine a key groove in your pulley...otherwise you need a keyed pulley to match.
Old 06-18-2007, 05:24 PM
14 Second Truck Club
mzoomora's Avatar
You could also remove the key. The keyed crank is nice, but if your setup doesnt require it, you could always take it out. Place a flat screwdriver or chisel under the curve and lightly tap it out. Do not gall the crank. You can take them out easily, always had to do it on SBC's before sending the cranks out. Tons of transmissions and older Jeep axles had keyways, never had a problem taking them out.
Old 06-18-2007, 05:27 PM
Black02SLPSS's Avatar
Ream it out!
Old 06-18-2007, 07:45 PM
LS1MCSS's Avatar
A machine shop should have a keyway cutter and the correct size mandrel to use. If they do, they can cut a keyway in 10 minutes. All it takes is the cutter and a press. Here is a link so you can see what the tools look like. http://www.hhrobertsmachinery.com/Ma...y_cutters.html
Old 06-18-2007, 08:26 PM
GTFORMULA's Avatar
I would go with having the pulley grooved also. Sometimes if you remove the keyway it will leak oil through the gap.
Old 06-19-2007, 10:05 AM
santiago's Avatar
thanks for the replys im gonna check into a local machine shop and see what they tell me.
Old 06-19-2007, 10:11 AM
SSpdDmon's Avatar
Is having a pulley machined for a key going to throw off the balance? I'd want to make sure of that before I spin my motor upwards of 6,000rpms...
Old 06-19-2007, 10:15 AM
santiago's Avatar
ya im jus gonna sell the asp and use that towards a new powerbond pulley
Old 06-19-2007, 11:02 AM
eallanboggs's Avatar
It's called a Woodruff shear key. They're used in all kinds of applications including your Briggs and Stratton lawnmower mag/flywheel. You don't need the key unless you're running FI. You can't tell from the photo, but unless the keyway is long enough that it goes past the timing cover seal you can just remove it without worrying about an oil leak. If the keyway does go beyond the seal surface and you don't want to go the expense of buying another pulley for $200.00. You can just get some keystock and cut it so that it is long enough to go from the snout to slightly past the seal surface to prevent a leak. Keystock is sold in SAE and metric and it is inexpensive. You may have to machine one face of the keystock down slightly so that the outer face(when installed) does not protrude above the crank surface. It has to be flush so that the pulley will slde on and not buck into the outer face of the key as you push the pulley on. A horizontal mill can make this simple cut. By the way a key goes in a keyhole and a key goes in a keyway, not the other way around. Try it sometime and you'll probably find that you can't get a keyhole to go into key or a keyway to go into a key. At least I haven't been able to get it to work, but I'm not a magician.
Old 06-19-2007, 12:43 PM
daryl2cb@yahoo.com's Avatar
if you decide that it might end up being cheaper to get a new pulley versus keying the old pulley, get the ati over the powerbond.
Old 06-20-2007, 12:06 AM
santiago's Avatar
well i did tell him i was gonna be spraying a 300 shot in the future so maybe thats why he put it on there.
what you said doesnt make sense. if its cheaper to get a pulley why would i spend $450 on an ati when a powerbond will do the same exact thing for half that price.
Old 06-20-2007, 06:44 AM
I'm more than a little curious as to how it is that you have a special crankshaft with a keyway machined into it, but you don't know what the "little piece of metal" is? That's oxymoronic.
Old 06-20-2007, 08:54 AM
mzoomora's Avatar
He clearly said that he just bought the block as an assembled piece. Apparently the builder thought it might be something he needed.
Also, an Oxymoron would be a figure of speech or a contradiction of terms. The fact that he didn't build the motor actually explains the key and keyway being there and him not knowing what it is for.
Old 06-20-2007, 09:00 AM
santiago's Avatar
thank you
