How safe is it too...
Old 06-18-2007, 01:40 PM
ChrisUlrich's Avatar
Default How safe is it too...
Rev a stock LS1 to 6500 but with rod bolts? Hopefully the engine would be making 440whp in that area. Any other precautions I can take to increase my bottom ends longevity? Well... when revving to 6500?
Old 06-18-2007, 01:53 PM
transamfreak01's Avatar
i think that you should be fine spinning it up to 6500
Old 06-18-2007, 02:03 PM
Krab's Avatar
Will you be on the stock cam? If so, why would you want to rev that high? Also, will the valve springs be upgraded? If not, I'd be a bit concerned with valve float at that rpm on the stock springs. The rod bolts should take care of the bottom end, but you have to pay attention to the valve train also. What is the stock limiter set to anyways?
Old 06-18-2007, 02:27 PM
Randy WS6's Avatar
I have a set of (ARP series 2000) rod bolts for stock rods if you need them, I had them in my stock 346 for a bout a month. Ill take $55.00 shipped ,pm me if interested
Old 06-18-2007, 06:18 PM
Mike94ZLT1's Avatar
At 6500 rpm your stock rod bolts will be fine. I used to rev both my cammed 99 LS1's to 6800 regularly, with stock rod bolts.
Old 06-18-2007, 06:24 PM
The car is gonna heads/cam setup on it... not a worthless rev. Just wanting to make sure the stock bottom end is gonna take it. Trying to make 430-440whp using a LS6 intake, stock heads (Ported of course), and a pretty large cam. Hoping for 120+mph traps. Stock 6 speed through a stock 10 bolt.
Old 06-18-2007, 07:11 PM
yeah youll be fine but i don think the 10 bolt will, they never are
Old 06-18-2007, 08:16 PM
Not worried about the 10 bolt... I just don't want my motor to pop
Old 06-18-2007, 08:35 PM
bluehawk2's Avatar
I am shifting mine at 6800 and have been on the rev limiter a few times. I deff think 6500 should be fine with the proper valvetrain.
Old 06-18-2007, 09:00 PM
HaulinHawk's Avatar
DITTO!!
Old 06-18-2007, 09:30 PM
A bad valvetrain would pop the bottom end?
Old 06-18-2007, 10:14 PM
bluehawk2's Avatar
An insufficient valvetrain could lead to dropping one of your valves.
Old 06-18-2007, 10:42 PM
Oh yea... I got that part down. haha The valvetrain isn't gonna be left out. I'm gonna have quality parts. But I want to make sure that my bottom end won't pop because i'm making 440whp and shifting @ 6500 rpms.
Old 06-18-2007, 11:09 PM
SS101's Avatar
the stock valvetrain usually doesn't start exhibiting valve float until @ or > 6800rpms, you should be fine
Old 06-18-2007, 11:38 PM
Emoney97ss's Avatar
what kind of revs would be safe for a completely stock bottom end?
Old 06-19-2007, 01:21 AM
Doc
Doc's Avatar
For your setup with no other information than in your sig I would give you a conservative 6200rpms.
Now everybody can jump in with whatever higher values they want but if this is your daily driver and you are a young person with limited cashe, for longevity sake, I stick by what I said.
Old 06-19-2007, 07:26 AM
melchoir's Avatar
I've been spinning my 98 to 6400, I just make sure I check the oil before I beat on it to make SURE it's full. Hopefully my stock rod bolts keep my car intact at this rpm.
Old 06-19-2007, 07:43 AM
ls2 bait's Avatar
i have a 99 with arp bolts and i shift at 6800 and my limiter is at 7 and ive tapped it twice. stilll intact. the 10 bolt-ya well its going to blow so start saving for a real axle.
Old 06-19-2007, 11:11 AM
Kryckter's Avatar
2001 motor 100,00 miles - Stock bottom end, including rod bolts.
488 RWHP - 6700 all the time
You should be fine
Old 06-19-2007, 12:39 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
2001 up engines have stronger rod bolts than 2000 and earlier engines do from the factory.
My 99 T/A has a stock bottom end and I tend to shift ~6,200 rpm with my set up. We set the package up this way to keep the rpm down in a nice safe area. I've hit the rev limiter which is set at 6,800 rpm a few times with no harm. Car has 93,000 miles on it. Has had heads and cam since 32,xxx miles.
Personally, 6,500 is the max I'd spin a stock bottom end 2000 or earlier LS1 to by choice. I like having more safety margin and like my ~6,200rpm shift points just fine.
Many early LS1's have been spun past 6,500 many times and held up.
Make sure the oil level is full before the high rpm stuff.
