Post up your popular H/C combo numbers with cam! Lets see what gets good gas milage
I would like to see what heads and cam combo makes good all around power but, still keeps a decent MPG. Im looking for a good H/C combo that wont send my MPG to hell! Post up your combo, compression, 6-speed or auto, gears, fuel pump, injectors, and anything that would effect MPG.
Combos im looking for
TSP PRC LS6 heads, and the 5.3 heads
MS4
MS3
V.3
V.2
HPE "S" cam
AFR heads
MS4
MS3
V.3
V.2
HPE "S" cam
AFR heads
I know my combo isn't listed, but just so you know. My setup is in my sig. Heads are milled .030". When I was M6, I got 20.5mpg highway, and about 17-18 mixed. 15mpg while driving hard.
Torquer2 112 +2 cam, with home brew heads @ 11:1 compression.
430 HP, 384 Tq.
25-26 MPG highway @ 75 MPH.
I dont bother calculating city milage, but Its probably really bad. Like single-digits bad. Its all in how you drive it. Around town, I cant help but get on it from every stop
430 HP, 384 Tq.
For combo see below for the 99 T/A. Note my set up is pretty old and with a mail order tune.
Typical 21-22 mpg, best highway 28mpg with heads/cam and 4.10 gears
Best before heads and cam. Typical 23.5mpg with a highway best of 32.8mpg.
A friend with a GM Hot Cam, FLP headers and 4.10's was able to get 26 mpg highway. I'm not sure what his normal mpg was but I think it was under 20.
LS1 Tech Administrator
26-27 mpg on highway. The AFR 205 heads and high compression are the key components. My AFR 225 heads and a smaller cam were about 1 mpg worse. Here are my mods:
AFR 205 heads with chamber opened up to 4.00" bore (to better unshroud the valves).
Standard 205cc CNC port work
Revised valve job for better low and mid-lift flow.
Heads milled to achieve 57cc chamber size (static compression 11.92:1)
Comp Cams 238/242 .605/.610 112LSA +3 cam with XE-R lobes
AFR upgrade 8019 dual valve springs. 170 seat, 450 open pressure.
AFR hollow stem 2.02 intake valves that weigh 98 grams each.
Forged shortblock machined by Erik Koenig from HK Enterprises, Houston, TX. Flat top Diamond pistons with 2cc valve reliefs.
7.400" pushords.
Comp R 875 hydraulic roller lifters.
Yella Terra 6645 Ultra Light shaft mounted rockers.
FAST 90 intake velocity ported by Tony Mamo.
Nick Williams 90mm TB.
No MAF (speed density tune by me).
Kooks 1 3/4" headers.
Custom y-pipe with LG Motorsports y-merge 4" collector, no cats.
4" Quick Time electric cutout.
10 bolt with 3.73 gears.
6 speed manual with Textralia OZ700 clutch.
7.400" pushords.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
7.400" pushords.
7.400" pushords.
