Milling Dart heads with a F14 cam and -2 cc pistons.
I was wondering how much I could safely mill my Dart 205 heads with 2.02/1.60 valves, .045 GM MLS gaskets and Diamond pistons with -2 valve reliefs, and the regular F14 cam.. and 7.35 pushrods.
I'm sure some may say to clay it.. but I was really hoping someone might have already done this.
If anyone knows how much I can safely mill them, what would the final compression ratio be?
Thanks.
Thanks.
Thanks, James. You're right, I was wrong, they are .052 part # 1258-9226
So it appears I could swing .035 off the heads and still have good clearance, but is there any way of knowing what my CR would be? I don't want to go over anything that will prevent me from running pump gas. I will also be running a 200 shot if that matters any.
Thanks for the responses guys!
It looks like the stock Darts are 62cc. Using that you and the stock gasket you should be around 10.71 SCR and 7.99 DCR. Milling to 59cc's would put you around 11.1 SCR and 8.29 DCR. Combining the milling and a .040 gasket puts you around 11.48 SCR and 8.54 DCR.
I bolded the around because FMS doesn't use comp grinds and the calculator I used is based on comp grinds.
The other thing to remember about his setup when figuring out the compression is that the Diamond shelf pistons usually come higher out of the deck than a stock piston does as well, so his compression will be higher than that with the .040 cometic
i fly cut my diamond pistons cuz they tell me am runing pretty close cuz of g5x3 and the 62cc. and the jucie too. i have the stock gm sheet metal gasket wht is the actual thickness of it.
could i go for .040 and run safly??? cuz its sound intresting to get mor DCR
how about milling to 59cc with that setup.
ooh one more thing :
i noticed that dart doesnt flow exhaust number verey good how about to port the exhaust doest it help ???
cuz most of the other market heads flow verey much higher than dart heads specially exhaust numbers .
Thanks.
Thanks.
Ok.. well it appears I am going to have a 358 rather than a 347 because the crank is offset ground. I am still trying to get a very accurate reading on what my compression ratio is.
Using this http://www.rbracing-rsr.com/compstaticcalc.html
Not knowing what my stroke is, but a 3.905 bore -2cc valve reliefs, 59cc chambers .040 head gaskets or .052 not knowing my deck height.. but reading where sigforty was at .011 I came up with 11.2 with the .052 and 11.6 with the .040 using what I think is the stock stroke of 3.662 (I am probably wrong on that, and I am not trying to act like I know what the hell I am talking about)
More help please?
More help please?
Dude, this gave me a freaking headache. Learn to type....
dude learn how to read loooool
the way i write is understandable for my home boys in US but if u cant then try to be take a long drive
Home boys??? What home boys?
Also what does this mean?
(but if u cant then try to be take a long drive)
And just to make things understood, I was only being Sarcastic... Lol
its ok man the problem is i type so fast so some time i type wrong words spelling etc...
but thanks for your advice anyway
and really am happy to get any correction anytime
see yaa
