Valve job questions? Is this true?
I was told that if I were to send my AFR 205’s for valve job that I would loose some Horse Power Due to the supposed fact that AFR has a proprietary valve seat design. Now I’m wondering if it’s worth it to send them out. I just want to clean them up, make sure their straight (since I was loosing a little coolant on nitrous), and mill them a little. I would like to hear all or anyone out there that recommends a good place to send them for a valve job?
Originally Posted by 99blancoSS
Why not just send them to AFR and get it done right? Call Tony and have the right people look them over in the first place. If they were Patriots you should send them to Gunnar at Patriot. But they're AFR's so send them to Tony at AFR.
Originally Posted by SmaknaSS
That was my first Choice but when I called AFR,. AFR told my that they only work on the heads if it's a warranty issue and that I will have to send them to an authorized AFR dealer instead. I was also informed(by one of the shops) that I might loose a little horsepower due to the supposed fact that only AFR has the proprietary valve desighn, Not the dealers. But all in all I'm very happy with my AFR 205's.
