FUEL with Heads and Cam >>
Im going to be installing my TEA stg. II heads, B1 cam, bolt-ons, hooker lt's w/ orp, and custom PCM. And i wasnt sure what else needs to be done to the car so it all will run smoothly. Im going to be buying the LS6 oil pump. But my question is do i need some new injectors or fuel pump or anything i dunno if the stock fuel system can keep up with the more air flow and more exhaust leaving quicker? Also what about driveline, can it stay stock tell i get some more $$. THANKS ALOT FOR HELPING ME !
IM EXCITED ABOUT MY NEW SET UP !!!
Re: FUEL with Heads and Cam >>
Ok good i wasnt sure. Ya the camaro is all my money but the vette is my car but my dealership (family owned for 73 years) pays for the mods. But i have just started buliding like 3 weeks ago i havnt even drive it yet! But thanks im having fun with it all!
stock fuel system will be fine.. Its not like you are bolting on 150hp. Usually when guys spray a 150 shot they get a bigger fuel pump
but for roughly a 80hp add on you will be fine
My 98 injectors where maxed out with my H/C setup. I would just check it with ls1edit or the Tech 2.
Albert
Albert
