is there a way to find out the specs of a cam without a cam card??
Old 06-21-2007, 11:19 AM
quiet_storm98's Avatar
Default is there a way to find out the specs of a cam without a cam card??
just wanted to know if there is any why to find out the specs of a cam if you dont have a cam card?? I recently bought a cam from a friend of mine for $50 and everytime i have asked him about the specs he says something a lil different. At first he told me it was a 224/228 then he told me it was a 226/226 and now everytime i ask him he tells me it is a 228/229 so i just want to know for sure what it is before i install it...thanks
Old 06-21-2007, 11:29 AM
BIG_MIKE2005's Avatar
If its a Comp cam, get the numbers off the end & call Comp. Thats what I did just to double check mine & they faxed me a original spec sheet for my cam that day.
Old 06-21-2007, 11:34 AM
stealth71's Avatar
Dial indicator and a degree wheel.
Old 06-21-2007, 11:47 AM
PREDATOR-Z's Avatar
^What he said^
Also a cam doctor analysis
Old 06-21-2007, 12:26 PM
o ok it is a comp cam so i guess i can just do that..thanks
Old 06-21-2007, 12:31 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
Getting the info from Comp is good but I would still want to put the cam on a Cam Doctor to find exactly what you have to work with. The actual cams will vary a little bit from the Cam card info, it's just the nature of the process.
The card will probably get you close enough.
Old 06-21-2007, 04:03 PM
LS1rulz's Avatar
Yeah doctor it yourself. Degree wheel and dial indicator did the trick for me.
Old 06-22-2007, 06:47 PM
thanks for the info guys..where would i get my cam "cam doctored" or where could i get or use a degree wheel and dial indicator??
Old 06-23-2007, 06:42 PM
anyone??
Old 06-23-2007, 07:17 PM
Randy WS6's Avatar
Try this here from Comp.Just type in the grind number off the end of your cam shaft >>>>>>>>>>>
http://www.compcams.com/Technical/Search/
Old 06-23-2007, 07:43 PM
LS1rulz's Avatar
Tolerances, man. Just because the cam is SUPPOSED to be a certain measurement doesn't mean it will be that. In fact, almost all of them are not an exact match for what they're supposed to be.
Old 06-24-2007, 12:53 PM
o ok thanks..that will at least give me an idea
Old 06-28-2007, 09:26 PM
i called up comp but they said they couldn't give me the specs because it is a thunder racing grind..so i am gonna send it to thunder racing for a cam doctor analysis...thanks guys
