How many have had Flycut their pistons?
Specificlly for the Trex or MS4 or 3. Stock or After market heads it does not matter.
if any other cam swaps required you to post as well.
Just curious i belive this will help me and other choose a cam for my build up.
thanks
thanks
Originally Posted by LightEmUpLs1
i called thunder raicng and they were tellin me fly cuttin is not nesscary all you do is shim your valves?!?!! WTF is this?
[QUOTE=SLP4CamaroSS]i didnt cut and i got a g5x3 112lsa cleance was .070/.110[/QUOTE .]
IMO that is already tight on a street hydraulic setup. (Intake wise)
Originally Posted by LS1rulz
Yup that's commonly where it should be
My old setup was 243 castings with a .010 mill, 2.02 intake valve, a .045 gasket and a TR224. It doesn't sound like it would be close, but I think those valves were what killed the PTVC. I was right within spec on that setup and was planning on a 230ish/234ish cam with more compression so I milled .080 to be safe.
In the end I have a 230ish/234ish 111LSA +2 cam, 11.2:1 SCR (.024 milling), a .045 gasket, and my PTVC was about 260 thousands on the intake and about 210 on the exhaust.
I'm sure alot of people have flycutt before. i did with my motor.
here's a good thread all about flycutting
https://ls1tech.com/forums/generation-iii-internal-engine/709183-how-flycut-pistons.html
Jon
Jon
Location: Your girl's back door giving her the long stroke while you're at work
I've got the 5.3/MS3 combo with 2.02/1.57 valves and TSP said no flycutting was required so I didn't. They also said it would be fine on spray
