What is the Oil Capacity in a 6.0 408?
I have been stumped since my 408 was put in my car.I am using my old LS1 oil pan.Is the Dip stick tube in the same location(Height wise)? Because my LS1 used to hold 5.5 quarts and Now my 408 holds 6 quarts????I asked my engine builder and he said it should be the same as my LS1 because its the same pan.I cant see where the dipstick tube goes in to see if its down all the way.I was smelling oil consumption when on the full mark but now that I am down to between full and add marks I am not smelling it now...What do you guys think?
Thank for the input
Thank for the input
LS1 Tech Administrator
Moved from Advanced Tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Other than the stock GM LS1 block that you used the pan and dip stick from, what block are you using now.. what else was changed ? are you sure that the tube is fully seated into the block ? If the block are physically the same and the tube is seated..
Then I would just drain it on the next oil change, fill it with 4 qt's. measure and mark the stick and then add the 5th qt and mark again. and if needed the 5.5 or 6th qt. just take your time to make sure it the oil is fully drained into the pan before you measure and remember that a empty oil filter does take up some oil once it is started.
