X1 vs C2 cam
X1 vs C2 cam
Is bigger really better here. Also if there is a slight HP difference between the 2 cams can the extra milling that can be done with the C2 cam make up for that difference. How much can you deck the heads without having piston to valve clearance problems with the X1. I believe i heard .060 with the C2.
