Yet another cam selection?
I'm looking for a cam that'll pull hard to 6800 but is somewhat tunable for little surge at very low cruising rpms. Or is that even possible on a Stock Bottom End LS1?
At first I thought T-Rex, MS4, etc... but I heard that they don't like being under 2k. Which is a bit high for when i'm driving around passed midnight.
So now i'm a little unsure about what cam will help me get my 120mph trap without sacrificing my 1500rpm driving.
Originally Posted by TORCHD 02 TA
i have a 228/232. That is a perfect cam. it pulls all the way till 6500... Mine is also cut on a 110. If i had to do it again, i woudl get it cut on a 112. the 110 is too tight. i had a lot of tunning issues.
idle clip in sig and numbers in sig too
So i'm guessing you have little to no cam surge when cruising between 1000-2000k rpms?
Originally Posted by ChrisUlrich
So if you got it on a 112... what would that be accomplishing as far as tuning goes? And doesn't the 110lsa help the cam make that power up top?
being cut on a 112, means that the amount of degrees you have in the cam makes it easier to tune. The 110 helps in the uppers R's.. Yup you have done your homework...
I have 'bucking' at 1500 RPMs. the car is making no powers and there is no load on the car. Get a gear and should be good to go. I prolly could use a little more timing too...
