Should I worry about cleaning the carbon off my pistons?
I'm in the middle of a H/C swap and while I'm cleaning the old head gasket material off, should I worry about cleaning the top of the pistons? If so, with what?
wouldnt hurt to bring them to TDC and use a Non abrasive cleaner and a scotch brite pad to clean them, hell use some seafoam since it wont hurt if ingested into the oil. and then just clean them up nice and shiny and you should be good
I just cleaned mine during my head swap and they look brand spankin' new. I used some brake cleaner and an emory cloth to get as much off as possible then I carefully used a flat razor blade to peel up the rest of the gunk that wouldn't come off with the cleaner. Then finish up again with brake cleaner and cloth. You'll be surprised at what they'll look like with a little elbow grease. Also, it's much easier to turn the crank bolt to raise 2 pistons to the top at a time.
I cleaned mine off also, might as well since you're right there. I used a razor to carefully take off the stubborn buildup, then just wiped it clean with some WD-40 and a shop cloth. Looked pretty damn new when I was done.
