Forged Malhe Pistons ???
Old 06-27-2007, 09:23 PM
95transamlt1's Avatar
Default Forged Malhe Pistons ???
I am recently having my ls1 block re build with new pistons rings and all the bearings and was wondering if malhe forged pistons are good cause they are the cheapest i can find do you guys know anything about them. I have a stage two head and cam package with all the bolt ons. What else do you guys think i should do to the engine since its out. thanks guys
Old 06-27-2007, 10:01 PM
Mike94ZLT1's Avatar
I've got Mahles, love them so far!
Old 06-27-2007, 10:05 PM
Mr. Luos's Avatar
Agreed.
Seem to be a great piston.
Old 06-28-2007, 12:00 AM
Jordan S.'s Avatar
I have them and plan to spray 200+. Guess I'll see how they hold up.
Old 06-28-2007, 01:59 AM
SuperZ's Avatar
They are cheap but they are good pistons and are light weight..Ive had mine in for about 2 years with 14psi and some nitrous every now and again.
Old 06-28-2007, 06:27 AM
slow trap's Avatar
since you are rebuilding the engine now would be a great time to put in some arp rod bolts also or if funds permit a set of decent h-beams. then you would have a very solid bottom end that would handle quite i bit of power.
Old 06-28-2007, 08:16 AM
11Second Club
Gauge's Avatar
+1 for getting new rods in addition to the pistons.
+1 for Mahles being a good buy. They're inexpensive, but they're supposed to be good pistons. The best part is that they come with the rings, too!
Old 06-28-2007, 08:41 AM
GuitsBoy's Avatar
+2 for both of Gauge's +1's.
Old 06-28-2007, 11:03 AM
john563's Avatar
I plan on using those pistons,cheap and well proven.I would add rod H beam rods like stated if you could,if not Arp 2000 rod bolts.Scat h beam can be had for pretty cheap
Old 06-28-2007, 06:29 PM
Unhappy
Ya i already ordered the pistons and rings and the arp rod bolts right now i can afford the rods so you guy have had no problems with them , thats great. Do you all know how much nitrous they can handle ?? thanks for all the input.
Old 06-28-2007, 08:25 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
+3
Nitrous wise I'm guessing they are something like a 4032 material for "small nitrous applications". Here's how it was described to me from the guys at Outlaw Motorsports.
Originally Posted by Outlaw Motorsports
All I have a is a Diamond Forged -2cc Dish Nitrous Piston. You have to figure small shots are around 300ish when guys are hitting foggers and around 1000hp at some cars with nitrous alone.
Make sure you invest in some Hellfire rings and have them fitted. These are a necessity! You will have to have them file fitted.
Forged piston only should take a 200 shot no problem.
Old 06-28-2007, 09:36 PM
even if i have stock rods and stock crank will it be able to handle a 200 shot ?? Im planning on 150
Old 06-29-2007, 12:02 AM
OWN3D BY MY PROF!
Yes, easily. That quote I posted was a stock rod and crank with forged pistons only. The rods only started to get wavy after a few bottles of the 300 shot off the transbrake.
Old 06-29-2007, 01:29 AM
SuperZ's Avatar
if you dont wanna spend the 450 or whatever on the scat H beams buy the scat I beams.Still 4340 and way stronger than stock and only 250$ I believe.
Old 06-29-2007, 02:01 PM
ok i think i am just gonna leave the rods stock and the crank stock and just spay a 150 shot of nitrous . With a 150 shot will the motor be safe and can i spray it alot at the track like that with no worries? thanks for all the input.
Old 06-29-2007, 02:52 PM
Viper's Avatar
Mahle's here too. Ligenfelter built my motor and they trust them in ASA racing...
Old 06-29-2007, 03:21 PM
OWN3D BY MY PROF!
I just created a thread about this. You can check it out here:
https://ls1tech.com/forums/generation-iii-internal-engine/739001-forged-347-forged-6-098-vs-6-125-rods-discuss.html
150 will be fine as long as it's tuned properly. You could even continue to push it more. I'm going to tell you though that those scat I beams are good insurance and in some instances cheaper than having your stock rods reconditioned. $250 with free shipping.....
Old 06-29-2007, 06:01 PM
zmonsterjb's Avatar
mahle is pretty good, how much are you paying for them?
Old 06-29-2007, 06:07 PM
my mechanic said like $422 i think.... How much do they cost ??
Old 06-29-2007, 06:16 PM
11Second Club
Gauge's Avatar
I think I paid $475-500 for mine with rings, pins, and locks. They're 3.903" bore, -9cc dished w/ valve reliefs.
