Lifter preload for LS7 lifters?
I initially had mine at .100 and found them to be a bit noisy. I changed my pushrods to 7.350 from 7.400 to have a .050 preload and notice that they are now a bit more noisy. Not too sure if you are looking for a quiet setup or a performance setup.
LS1 has been out 10 yrs. and this info is not a sticky. Has anyone ever measured the preload when taking the engine apart? The same can be said for:
1. head gasket thickness
2. deck height
3. lifter dimension, i.e does the Cadi lifter need a diff length pushrod
4. port volumes on old and new heads
2. deck height
