Bell Jingling noise...
Old 06-29-2007, 08:58 PM
ohhiitznik's Avatar
Default Bell Jingling noise...
Well My car just turned 100k miles, and im way away from home. I have a jingling noise coming from the front or the front passenger side of the motor, almost sounds like a bell, anybody have any ideas on what this could be? motor runs/idles fine, just makes a funky noise. I'm thinking its the roller rockers or something on the top end, but the thing is I don't hear it speed up when the motor revs. Anybody have any ideas on what it is?
Old 06-29-2007, 09:09 PM
01redws6ta's Avatar
When you turn the A/C on, does the noise go away or change? Sounds like possible A/C compressor clutch dragging when compressor is off.
Old 06-29-2007, 09:42 PM
ohhiitznik's Avatar
damn it! hehe
ohhiitznik's Avatar
Gunna check it out!
Old 06-29-2007, 10:01 PM
ohhiitznik's Avatar
Didn't seem to fix the problem, any other ideas?
Old 06-29-2007, 11:17 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I've had all sorts of weird *** rattles in my car. The original one was the damn spare mount was just sitting in the spare tire well and making an awful noise. Then one of the headlight covers was loose.
You could be having some piston slap / knock? It usually sounds like marbles.
Old 06-29-2007, 11:20 PM
ohhiitznik's Avatar
This sounds like bells, like jingle bells, coming from lower passenger side of the motor motor revs fine, and sound doesnt seem to escalate, maybe the alternator jingling for no reason? I dont think its in the motor because It doesnt seem to speed up the jingle when I give it gas
Old 06-29-2007, 11:22 PM
ohhiitznik's Avatar
doesnt seem to be a rythmic sound either, just kind of random jingles...
Old 06-30-2007, 07:27 AM
DaddySS's Avatar
You need to look at parts that can cause this - pulleys, water pump, PS Pump, exhaust clamps, pipes, hangers, shields, clutch, etc.
Start by removing the belts, then get under the car and check the other stuff.
Old 06-30-2007, 02:07 PM
Regginator's Avatar
Does it sound like this....
Click here to see Video
Old 06-30-2007, 02:30 PM
7camaro7's Avatar
I have the same sound that guy is describing and I've since then put on lt headers and I've still got the sound. I've looked everywhere no luck. It does NOT sound like this video either. That definitely sounds like its coming from the passenger side head.
I've given up on looking for where mine is coming from since it drives fine.
Old 07-02-2007, 04:28 PM
ohhiitznik's Avatar
SOunds EXACTLY LIKE THAT, but it has since stopped....
Old 03-02-2021, 12:13 PM
Tony-SS's Avatar
I am resurrecting this SUPER OLD thread. Sorry all.. I have this exact sound. Has anyone addressed this since 2007?
Old 03-04-2021, 05:39 PM
01CamaroSSTx's Avatar
Received 1,785 Likes on 1,293 Posts
Remove the serpentine belts momentarily and start the car to see if it goes away would be the first step or with the engine running take a 3-4 foot piece of garden hose and put one end to your ear and with the other end move it around over the engine to see if you can isolate where the noise is coming from.
A/C compressor and/or tensioner pulley or belt
Main serpentine belt or the tensioner and/or idler pulley
Water pump
Alternator
Power steering pump
I just replaced both of mine last year but another thing to consider is an electric fan motor on its way out.
The following users liked this post:
G Atsma (03-04-2021)
Old 03-05-2021, 09:07 PM
wannafbody's Avatar
I had a jingle sound over bumps. Never could find the source. About 5 years ago I pulled the intake to replace it and found a 10mm socket laying on the valley cover. Must have been dropped during assembly.
G Atsma (03-06-2021)
Old 03-06-2021, 01:12 AM
Received 3,017 Likes on 2,348 Posts
And a proverbial 10mm no less.... lol
The following 2 users liked this post by G Atsma:
01CamaroSSTx (03-06-2021), wannafbody (03-06-2021)
Old 03-06-2021, 10:27 AM
Moderator
Darth_V8r's Avatar
Received 1,835 Likes on 1,145 Posts
The following 3 users liked this post by Darth_V8r:
01CamaroSSTx (03-06-2021), G Atsma (03-06-2021), Woodylyf767 (03-16-2021)
Old 03-16-2021, 10:00 AM
Tony-SS's Avatar
FOUND MY ISSUE !!!!!!
The Air / Smog Pump Check Valve on the passenger side was faulty. The hose was crazy hot meaning the valve was bad. Driver side was not hot at all. So, order a valve from rock auto, be here today. I will report if this fixed it. However, I believe it will since the noise was coming from that valve.
wannafbody (03-16-2021)
Old 03-18-2021, 08:49 AM
Tony-SS's Avatar
Found my issue, here is a small vid to show you guys!!!
The following 2 users liked this post by Tony-SS:
01CamaroSSTx (03-18-2021), xny1989 (05-03-2021)
Quick Reply: Bell Jingling noise...
