Front seal
Front seal
The seal that is behind the harmonic balancer is leaking. Do I have to pull the whole waterpump and timing cover off to change the seal or can I pull the pulley off and pull the seal out and put a new one in. Any help will be greatly appreciated.
You do not have to pull the whole thing apart. Just remove belts and pulley/balancer and use seal puller from underneath car to pull seal out. Be carefull with the seal puller not to mark up the seal mounting surface. Install new seal with installer or deep socket which is close to same diameter as seal outer surface making sure you install it square and not crooked in the cover. I always put a light coat of grease or oil on lip seals before installing too. Then reinstall pulley and belts and run and recheck your work.
Originally Posted by the.erinyes
DO NOT USE GREASE OR OIL on LS1 main front or rear seals. You will ruin them. They are teflon type seals and do not require grease or oil!
yeah i also dont think i agree with that statement, i put some oil on mine with my finger b4 i put my cover on, few thousand miles later still good
