Turning a crank?
Old 07-02-2007, 07:19 PM
LS1rulz's Avatar
Default Turning a crank?
How deep can one take off an Eagle stroker crank and it still be considered good?
Old 07-03-2007, 08:43 AM
LS1rulz's Avatar
Anybody?
Old 07-04-2007, 11:41 PM
LS1rulz's Avatar
So nobody knows anything about cranks?
Old 10-28-2013, 08:18 PM
Vetal's Avatar
I've got the same question - how much can you turn Eagle crank?
Can I safely turn .01", or should I try to stay with .002" and Sealed Power rod bearings (2555A2)?
Old 10-28-2013, 09:22 PM
KCS
Moderator
KCS's Avatar
.010" is fine, no big deal at all.
A word of advice, if you get your bearings in advance you can measure the ID of the bearings in the mains and/or rods with the caps torqued and tell the machinist exactly what OD to turn the crank to to get your exact bearing clearance. I do this all the time and if you do t work in a shop and have access to a large selection of different sizes, this is a good way to avoid buying several sets and mixing and matching.
Old 10-29-2013, 02:24 AM
Vetal's Avatar
Thing is, I don't want to do .01" now because that gives me 1 more time less life on the crank. So I'm trying to stay with .002" (found these SP bearings, don't know how good are they)
Old 10-29-2013, 06:11 AM
Busted Knuckles's Avatar
Don't worry about .010 cut on the crank. That's less than 1/2 of 1% of either main or rod journals. If it's done right with a good radius on the filet, it will be stronger when he's finished than when he started. And a .010 cut means you'll have taken .005 off of each side of each journal, should be well under the depth of any hardening done by Eagle. Racers cut rods down to Honda journal size all the time with no crank issues.
Old 10-29-2013, 06:31 AM
Vetal's Avatar
I'm sure .01 less diameter (diameter, correct??) will be still within hardened layer, but what if I ever need to turn it again? .02" might fall below the thickness of the hardening :s
Old 10-29-2013, 12:43 PM
KCS
Moderator
KCS's Avatar
Why are you turning the crank in the first place?
Quick Reply: Turning a crank?
