pushrod length with TSP 5.3L heads
I will be using a TR 224-112 cam, TSP 2.5 5.3L heads, new stock LS1/LS6 lifters, stock rocker, etc. I will be using the stock GM head gaskets. TSP recommended 7.4's while Patrick said he would probably do the 7.425's. What do you guys think?
I am not sure if one is easier on the valvetrain or if one will keep it quieter?
Originally Posted by Grimes
wondering why you didn't have them milled? I would at least do .010 or .015 for more compression
-William
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by PREDATOR-Z
Both will work, the 7.425 will add .015 preload and make things a little qieter.
Originally Posted by SSDriver
Depending on the size of his cam he might not of had a choice to mill lol. If the block is a 2000 you have the long bolts. 2004 is when GM changed the blocks where they have all short bolts.
-William
-William
Originally Posted by cals400ex
maybe i didn't make it clear in the first post. i am sure i would have room to mill. i just went with what TSP said. so you are thinking 7.425 with the 5.3L heads and a TR224 cam using stock GM gaskets?
7.400 will work but a bit noisier (less preload)
