piston to valve clearance check??????
Old 05-11-2003, 12:45 PM
malibu350's Avatar
Default piston to valve clearance check??????
Does anyone know how to do a piston to valve clearance check, if you don't have a solid lifter or lighter spring??? Any help would be appreciated.
Old 05-11-2003, 02:26 PM
needmoremoney's Avatar
Default Re: piston to valve clearance check??????
all I did was put playdo (CLAY) on the piston, put the head on (no gasket) put a few bolts in, install the intake/exhaust rockers, pushrods, and hand turn the motor over twice, being very carefull. Take the heads of, and look at the clay. I have a digital micrometer, i measured the deepest indention in the clay and added .53 for the head gasket. Does this help at all?
Old 05-11-2003, 03:46 PM
malibu350's Avatar
so I take it you had no problem at all? That does help to know that it will still work? Did you do anything w/the lifters at all??? Thanks again!!!
Old 05-11-2003, 03:55 PM
Ya I had a problem, as soon as i looked at the clay, I saw a fine (HAIRLINE) scratch on the piston I had to exchange my 5.7's for SII 5.3's
Old 05-11-2003, 04:07 PM
malibu350's Avatar
What type of cam and rockers were you running? What were the heads decked at? Valve sizes? The reason that I'm asking is because I have some heads that are decked .040. W/ 2.02 and 1.6 valves, crane 1.8 rockers, and the ASA cam. W/ 525/525 lift and 226/236 duration. I've been told that I will have no problems but I want to make sure that I wont. Thanks
Old 05-11-2003, 06:16 PM
I can almost bet, that you might/will have a clearance issue I was going to run 5.7 SII heads milled .30, as soon as they came, I did the clay trick, and sure enough, they hit the piston. The rockers i was using were the stockers. The valve sizes were 2.02/1.55. My new heads that are coming are 5.3 heads milled .05 SII 2.02/1.57, and now im using the new yella terra 1.7 shaft roller rockers . Wish me luck
Old 05-11-2003, 07:04 PM
malibu350's Avatar
WEll then let us all say a prayer to the car gods that I'm fortunate and nothing goes wrong...
Old 05-11-2003, 07:37 PM
Good luck
Old 05-13-2003, 07:35 AM
robertbartsch's Avatar
Cometic sells thicker-than-stock gaskets if you like or you can flycut the pistons...
...i think thunder racing rents a seatless head with a cutter for this exact purpose...
