Highest valve lift w/stock bottom end
Old 05-12-2003, 01:03 PM
malibu350's Avatar
Default Highest valve lift w/stock bottom end
I was wondering what's the highest lift anybody has run w/the stock bottom end, since the stock pistons don't have any valve reliefs.
Old 05-12-2003, 02:04 PM
NO CATZZ's Avatar
Default Re: Highest valve lift w/stock bottom end
It is not just lift that you need to be concerned with. It is the relation of lift and duration together that will ultimatly determine the amount of lift you can get away with. Other factors would be valve angle and size.
How is the install going?
Old 05-12-2003, 03:29 PM
malibu350's Avatar
okay enough input from the peanut gallery :p But with that in mind 2.02, 1.6 valves w/five angle valve job and a cam w/525(555) after rockers. And duration of 226, 236.
Old 05-12-2003, 11:50 PM
malibu350's Avatar
TTT
Old 05-13-2003, 12:13 AM
TireFryer30th's Avatar
soo your running an ASA cam? and you say after rockers soo I am assuming your going with 1.8 rockers.
I believe the highest lift cam on the market for LS1's right now is the G5X2 which I believe the lift is .590/.610 but I cant remember the rest of the specs.
The ASA cam seems to be very popular and people are making good #'s with it. I was actually thinking of going with this cam, but am probably going with something bigger.
TireFryer
Old 05-13-2003, 09:07 AM
Fahad's Avatar
Hi
The highest lift on stock G5X-2, correct me guys if i am wrong!
what is the specs of ASA cam? i have a soundclip for ASA cam at idle, it's very awesome
TireFryer30th, the reged it's same : 06/04/02
Thanks
Old 05-13-2003, 09:44 AM
RB185AFM's Avatar
The ASA cam is 226/236 .525/.525 110 LSA
Old 05-13-2003, 11:56 AM
malibu350's Avatar
Yes that is the specs, but it comes out to approximately 555 after the installation of the crane 1.8 rocker arms.
