View Poll Results: What Loctite did you use?
Blue Serviceable - Medium Strength
8
40.00%
Blue Serviceable - High Strength
1
5.00%
Red Non-Serviceable - Medium Strength
1
5.00%
Red Non-Serviceable - High Strength
10
50.00%
Other I.E. (ARP Thread Locker)
0
0%
Voters: 20. You may not vote on this poll
What Loctite did you use on your cam install?
Old 07-11-2007, 11:31 PM
SweeTbone's Avatar
Default What Loctite did you use on your cam install?
Looking to do my cam install Sunday, but I'm not sure as to which Loctite to use. The writeup on LS1howto.com said to use Red Medium Strength Loctite, but I haven't found that anywhere, only high strength, with a hold rating of like 200 ft/lbs. I've read that others have used Blue Serviceable. Which one do you guys recommend?
Old 07-12-2007, 01:08 AM
cals400ex's Avatar
I used the blue medium strength on most places. On the head studs I will use the ARP thread sealer, I just haven't got that far yet on my build.
Old 07-12-2007, 09:05 AM
brad8266's Avatar
red high. You can break em loose if you need to eventually. At least you wont have to worry about bolts backing out that way.
Old 07-12-2007, 03:04 PM
Websy21's Avatar
Meet in the middle, Red Medium. http://www.ls1howto.com/index.php?article=23
Old 07-12-2007, 06:13 PM
gillbot's Avatar
i used red high on mine and the wife's.
Old 07-12-2007, 06:16 PM
098z28's Avatar
i actually didnt use any..
Old 07-12-2007, 06:18 PM
brad8266's Avatar
Dumbass
J/K man, although it would be good insurance to use it, you dont want a cam bolt backing out on you when some loctite could save you the headache and knuckle busting of having to tear back into the front cover.
Old 07-12-2007, 06:28 PM
ProjecT 9's Avatar
red, high
Old 07-12-2007, 09:09 PM
SweeTbone's Avatar
Originally Posted by SweeTbone
Looking to do my cam install Sunday, but I'm not sure as to which Loctite to use. The writeup on LS1howto.com said to use Red Medium Strength Loctite, but I haven't found that anywhere, only high strength, .....
Umm yeah. I know about the writeup. I can't find Red Medium at Autozone or Napa. Couple of other places to try, but I'm leaning towards Red High, even though the poll currently is tied at opposite ends with Med Blue and High Red.
Old 07-12-2007, 09:21 PM
98C5LS2's Avatar
I'd be curious to know how many times losing a cam bolt has actually happened. GM specifically does not call for Loctite on these particular bolts. The manual says if it did, they would make a special note about it.
Old 07-12-2007, 09:33 PM
SSsuperdave's Avatar
I didn't use any either. GM manual didn't call for it,so I guess time will tell. If I could do it over I would use some kind of loctite, though. Just 4 peace of mind.
Old 07-13-2007, 10:39 AM
405HP_Z06's Avatar
I would recommend Loctite 246. It's a high temperature, medium strength oil tolerant thread locker.
The high strength thread lockers are way over kill for these small fasteners, but for a high stength, Loctite 266 would be my choice. It's a high temperature, high strength oil tolerant thread locker.
Old 07-13-2007, 11:10 AM
vettenuts's Avatar
Which fasteners are we talking about?
Old 07-13-2007, 09:49 PM
White_Ls1's Avatar
I used the medium strength blue, but only on the oil pump, rocker and the pulley bolts. I did however tighten everything to specs.
Old 07-14-2007, 12:19 AM
098z28's Avatar
yeah i would next time to i just got all 'gunghoe' and had to get everything back together right now! lol u all know how it goes
Old 07-14-2007, 06:15 PM
SweeTbone's Avatar
TTT for more opinions for tomorrows install. (Hopefully)
Old 07-14-2007, 07:33 PM
GT Griller's Avatar
Me either.
