6.0L Rods and Pistons
Old 07-13-2007, 06:21 AM
nobreaks254's Avatar
Default 6.0L Rods and Pistons
Does anyone make a 6.125 rod with the stock .945 pin? I was thinking about trying to use them on my stock pistons and mill .025 off the pistons. Basically I'm trying to increase my compression. Down the road I would like to do a 4" crank. So if the rods I want are available, would there be stroker pistons available with the .945 pin? I'm open to other ideas as well. I will be useing the stock 317 heads and really dont want to replace them at this time. I do have a stock set of 241's if that would be better.
Old 07-13-2007, 12:10 PM
nobody has any thoughts?
Come on guys, help me out!
Old 07-13-2007, 01:05 PM
LS1MCSS's Avatar
The closest thing I can find is an Eagle rod that 6.100 long. It probably won't help, but the p/n is CRS6100M3D. According to the Carrillo website, their rods can be honed on the pin end for the .945 pin. Scroll down and look at the LS1 rods.
http://www.carrilloind.com/portals/1..._Layout_02.pdf
