11:1 compression to high for a daily?
Old 07-14-2007, 04:01 PM
Reject's Avatar
Default 11:1 compression to high for a daily?
was wondering if a compression ratio of 11:1 would be safe for the street. i've heard of a couple of people driving 11:1 head/cam combo's on the street, but never really heard of them daily driving it all of the time. would it be safe/stupid to run that high for on the street. i'm looking at the p/n 2033 Patriot stage II heads with 2.055"/1.57"/59cc and (already have) a patriot 226/226 .585"/.585" 112LSA cam and (will) toping it off with the LSX intake and a 78MM TB.
again just wondering if anyone runs that high of a compression for on the street as a daily driver, thank you!
Old 07-14-2007, 04:46 PM
gts500's Avatar
it should be fine .
Old 07-14-2007, 04:51 PM
edcmat-l1's Avatar
Yes....
And, yes.....
Old 07-14-2007, 05:15 PM
DaveX's Avatar
Mine will be 11.3 soon. But you really need to look at your dynamic compression ratio also, not just static.
Old 07-14-2007, 05:20 PM
pdd
pdd's Avatar
mines 11.3:1- it runs drives perfect and could be drivin everyday-all day
Old 07-14-2007, 05:23 PM
CoozePoodle's Avatar
All depends on cam specs my good man.
Old 07-14-2007, 05:59 PM
slow trap's Avatar
i agree. i ran 11:7 scr and dcr was suposedly 9:0 but in reality it was probably only 8:9 or so on 93 without any issues whatsoever.
Old 07-14-2007, 06:29 PM
Reject's Avatar
would the info about the heads and cam be enough info to figure out that information? it's all on a stock block with 7.400 pushrods if that helps any?
Old 07-14-2007, 06:37 PM
brad8266's Avatar
im at about 12:1 and it is easily daily driveable
Old 07-14-2007, 07:30 PM
Reject's Avatar
how easily is it able to find gas? are you just putting 93 in and not mixing it with racing gas?
Old 07-14-2007, 08:10 PM
Wilkenstein's Avatar
What is considered a good safe limit for DCR on pump gas? I'd like to run about 8.8 or so after heads.
Old 07-14-2007, 08:13 PM
98C5LS2's Avatar
Heck, new Acura TL has 11.0:1 and doesn't have near the overlap your cam does so no sweat. Compression is a free lunch. More power and better economy.
Old 07-14-2007, 10:07 PM
Dragula's Avatar
Static Compression Ratio often referred to as Compression Ratio is not the primary determining factor for engines running on a predetermined octane fuel.
Dynamic Compression ratio is the major factor!
The later the intake valve closes ABDC, the less air fuel mixture is trapped in the cylinder. This in sense lowers the compression ratio. This is also why large cams with stock rotating assemblies have more advance ground into them.
In fact Toyota has a 1.5L engine on a production vehicle that has a 13:1 SCR and runs on regular unleaded. High Static Compression Ratio does not always mean it requires high octane fuel.
Quick Reply: 11:1 compression to high for a daily?
