Setting up 918 with stock heads
Changing out cams, the hot cam was to small. Replacement will be Comp XE 224/224 565/565 106icl 110lsa . Will need new springs and wanted to go with the 918's but do not no what size spring seat to use for this setup if any. I will be using stock retainers and also am wondering if piston/valve clearance would be a problem
I am picking this cam for good torque I don't like to spin more than 6200rpms unless it is a built motor like my buddies this, car is a daily driver.
