Patriot dual valve springs
Old 07-17-2007, 10:46 PM
delsold's Avatar
Default Patriot dual valve springs
are these known to be a noisy valve spring? after installing them, and properly heat cycling them before seeing any rpm over 3000ish, they still seem to be noisy. My car sounds like a sewing machine haha
Old 07-17-2007, 11:22 PM
sroach20's Avatar
are you using the right size pushrods? im running xer lobes and mine is a little noisy.
Old 07-18-2007, 01:47 PM
delsold's Avatar
i believe so. im using stock rocker arms, patriot 226/226 .585/.585 112lsa, patriot duals, and comp 7.400" pushrods. from what i heard this setup should be fine. It runs perfect, just with the radio off (or quiet) and windows either up or down i can hear alot more mechanical noise under the valve covers. doesnt sound bad...just noisier than stock
Old 07-18-2007, 02:36 PM
sroach20's Avatar
find out the size of the cam. i dont know about patriots but some cams have smaller base circles than stock, so people run 7.425 pushrods.
Old 07-18-2007, 07:17 PM
98RedZone's Avatar
I run a LSK lobe on the intake (.640 actual lift) with the Patriot Extremes, and i don't think it sounds that bad. I am using 7.450" Comp pushrods.
Old 07-18-2007, 09:52 PM
916LS1's Avatar
I'm running the Patriot Duals with a 224/224 581 581 cam, stock rockers, and 7.400 pushrods. They were very noisey at first, but I think it might have gotten better with a little mileage. Either that, or I just got used to it...
Old 07-19-2007, 01:41 PM
delsold's Avatar
ya i was hoping they would get better with time. its not a bad sound, just alot more mechanical noise than stock
Old 07-19-2007, 01:54 PM
BIG_MIKE2005's Avatar
Thats very wierd b/c I have that exact same set-up & it's quieter than it was stock. Maybe my 5.3 heads being milled .018" helped it out some??
Old 07-19-2007, 11:40 PM
mvvette97's Avatar
I run the Comp 228/230 cam with the Patriot duals and it's noisy. I installed a set of 7.425 pushrods and it's still noisy but not quite as bad.
Old 07-20-2007, 11:14 AM
Redlinez's Avatar
Both my cammed ls1 cars were quite noisy. I'd call them clackity, like something was loose.
Old 07-20-2007, 03:07 PM
sidewayz28's Avatar
ur guna have to deal with that sewing machine sound.. but who really cares about sound when u start throwing in a cam & new valve train?u could get louder exhaust?
Old 07-20-2007, 04:56 PM
delsold's Avatar
i like where your heads at
